Recommend a flywheel
Discussion in 'Transmissions' started by 007GT, Apr 9, 2017.
What flywheel to use for 302 ho mustang motor in comet and standard trans.
  1. order online
    1 vote(s)
    100.0%
  2. order at auto supply
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. 007GT
    007GT Member
    HOUSTON
    74 MERCURY
    Just broke a tooth and now need a flywheel for 302 HO motor from 88 mustang in my comet. Please
    advise which flywheel to use with standard transmission.
  2. yellow75
    Tillamook Oregon
    Probably a 157 tooth 50 oz or you could just have a new ring gear put on it. Prices are all over the place from $ 65.00 for resurfaced used to $400.00 new Ford Racing
  3. rthomas771
    Check with your local machine shop. I had my flywheel resurfaced and ring gear replace for under $55
  4. William623
    Orlando
    1973 ford maverick grabber
  5. rthomas771
  6. William623
    Orlando
    Sorry you are correct I read the post too quickly.
  7. bmcdaniel
  8. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    if you need to buy a new Flywheel I just Bought a new safety certified PRW Flywheel for 265.00 and it has the removable Weight so it can be balanced from neutral to 28 oz or 50 oz. It was cheaper than a stock replacement.
  9. bmcdaniel
    You must of been looking at the solid gold version stock flywheels....
    Krazy Comet likes this.
  10. Krazy Comet
    Or at least 24Kt plated....
  11. Mavit
    Mavit Member
    Prince george bc
    and were do you smart ass 's get a new stock replacement for less? I was quoted 279. 99 for a new ford stock Flywheel.
  12. rthomas771
  13. Krazy Comet
