Recommend me a mini starter
Discussion in 'General Maverick/Comet' started by satchelmcqueen, Aug 27, 2019.
  1. satchelmcqueen
    satchelmcqueen Member
    north georgia
    So yall recommend me a mini starter please. I have a 70 302, with a 157tooth flex plate, hooked to a 250 c4 trans.
    As always tha ks
  2. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    I believe most guys are using a stock starter form a 1990’s 5.0.
    yellow75 and greasemonkey like this.
  3. mojo
    Do the 1990's starters have the 157tooth gears for his setup?
    satchelmcqueen likes this.
  4. satchelmcqueen
    north georgia
    Yes this was my next question. Anyone know?
  5. BBMS18
    BBMS18 Member
    75 Comet
  6. Rick
    Rick G8I operations
    Ocala, Florida
  7. satchelmcqueen
    north georgia
  8. rthomas771
    Same starter for 57 tooth and 164 tooth if using automatic transmission. The 164 tooth on a manual transmission is different starter
  9. stumanchu
    stumanchu Stuart
    Portland, OR
  10. William623
    Orlando
    1973 ford maverick grabber
    I used a stock 5.0 mini starter off a 93 mustang I think? Works fantastic.
    satchelmcqueen and BBMS18 like this.
  11. Krazy Comet
    But that's only on early engines, I think you have to go all the way back to mid/late '60s 289 before the starters are different between auto and manual.
    EDIT
    Looks like there are different late auto & stick starters, actually easy to tell if you know the difference, stick starters have a shorter nose than auto. In the late '60s & '70 I used the long noise auto on everything(which was a '69 351, 4-speed Fairlane). I've even installed three bolt FE starters on small blocks.
    I've had one of the ebay PMGR $35 specials on the Comet since '14. Also one on my '96 5.0 F150. for last couple years.
    jasonwthompson and BBMS18 like this.
  12. stumanchu
    stumanchu Stuart
    Portland, OR
    Does anyone know why ford made a 164 tooth bellhousing and flexplate to begin with?
  13. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    To fit 12" clutches and larger, heavy duty torque converters.:huh:
  14. Krazy Comet
    Back when the 164 was used in trucks and maybe fullsize models. For C4 easily ID by the pan fill transmissions. As time progressed and Ford modified the C4 into C5, most all auto trans morphed into 164T(I believe all C6 are 164 & all AOD are 164). Late 5.0 stick generally have a 157T, HD applications a 164.
    stumanchu likes this.
  15. BBMS18
    BBMS18 Member
    75 Comet
    mojo likes this.
