Recommend me a mini starter
Discussion in 'General Maverick/Comet' started by satchelmcqueen, Aug 27, 2019.
  1. stumanchu
    stumanchu Stuart
    Portland, OR
    lol....Who needs google when Tom is in da house?
    Hotrock, satchelmcqueen and Shorty like this.
  2. Krazy Comet
    Dismal Swamp
    LOL
    I should have said I think the small block C6 uses 164T, big blocks use one in the 184T range.
  3. bmcdaniel
    I learned the difference between the short and long nose pieces back in the late '70's when the kid at the parts store gave me a long-nosed starter for a manual trans '66 Mustang. I didn't know the difference, yet. Tore about 1/3 of the teeth off the flywheel ring gear when I tried to start it. Now I keep the short nose piece to swap over onto an auto starter.
  4. rthomas771
  5. bmcdaniel
    Read that article. There must be a difference between the early 157 tooth flywheel, as used in the '66 Mustang and has a C3XX engineering code, and the later 157 tooth flywheels. In my case the longer nose allowed the starter pinion gear to go so far forward that it barely engaged the front of the flywheel starter ring.
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    How many teeth would my c4 form a 1978 F-150 have if I wanted to buy a mini starter.
    Edit.. Looks like the 157 / 164 teeth take the same starter. So I hope I have one of those?
  7. Krazy Comet
    Dismal Swamp
    AFAIK 99.9% small blocks used the 157/164 flexplates. Lone exception I can think of were the 148-ish count used on Mustang II
    I've never seen that amount of teeth on flexplate/flywheel makes a difference. The pit fall is depth of teeth, which dictates the length of nose. As I mentioned in earlier post, I've used FE starters on small blocks.
    smegnl likes this.
  8. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    I got tired of counting teeth..
    157 is 13.25
    164 is 14.25
    CaptainComet and Krazy Comet like this.
  9. rthomas771
    Most 62-66 SBF flywheels was 160 tooth.
    Not all SBF are 28.2 or 50 ounce...
    62-’63 221 were 23.1oz
    ’62-’63 260 were 24.5oz
    ’64 260 were 26.2oz
    ’63-’67 289 were 28.2oz
    ’63-’67 298 HiPo were 24.7oz + 5.9oz counter-weight (34.4 total)
    Krazy Comet likes this.
  10. Krazy Comet
    Dismal Swamp
    Wasn't the 160T flywheels used in the five bolt bell housings? Those ended with true '65 289 engines.
    Admittedly I wasn't really thinking about pre 289 engines. Unless concours restoring a '63-'64 Falcon or 64½ Mustang, no one wants a 260 & the 221 gets no love at all.
    A friend recently tried to give me a '62 Fairlane 4-door parts car with 221. Was horribly weathered(possibly in flood), no floor boards, dash rusty, even tip of dipstick had rusted away. Told him to scrap it.
    BTW & FE starters? Actually cross with 170/200(probably 144)
  11. Powerband
    Powerband Member
    NY's \H/
    ’64 260 were 26.2oz
    ... and some SBF's use an EXTERNAL or NEUTRAL balance Flywheel not 28oz or 54 ...
    https://www.ebay.com/sch/i.html?_fr...c=0&_sop=10&_osacat=0&_odkw=ford+flywheel+4.1
    Fortunate for Ford Small Block Six enthusiasts, the Anvil like' 250 Six in lots of Mavericks' uses all Small Block V8 157 T parts from block back - Flywheel , Starter, Clutch and Bellhouse are same as 302 enabling simple tranny upgrades .
    [​IMG] .[​IMG] . [​IMG] . .
    [​IMG] . [​IMG] . [​IMG]
    ... not clear if V8 Starters will ever fit the 200 (170/144) but V8 will definitely fit the 25o Six with V8 bellhouse-starter config'.
    (Some late 200's ( @ 79-81 Mustang, Fairmont,?... ) use a specific Automatic (Jatco?) only 'low mount starter' bellhouse - probly also uses V8 starter .
    250/C5DA V8Bell, T5 adaptor and Hooker headers:
    .. with OEM starter:
    [​IMG] . [​IMG]
    ... with PMGR 'mini' starter
    Have fun
    mojo likes this.
  12. Krazy Comet
    Dismal Swamp
    Aftermarket, zero balance AFAIK not from factory. Found nothing in FMPC.
    From FMPC, FE & 200 starter listed together. There was a FE 3131 parts house starter on the 200 Comet I junked.
  13. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    I have a Jegs brand mini-starter on my 421W stroker motor and am very pleased with it. The original starter didn't want to crank that big motor when it was warm so I switched to the Jegs. I think it has been on there about ten years without a problem.
    Lee "THE MAV" Richart
