Reinstall power steering
Discussion in 'Technical' started by timers, Dec 7, 2018.
  1. timers
    timers Member
    richardson tx
    1974 maverick
    I decided to put my power steering back on my 74 mav 302. I have every thing but the pressure hose and the return line my pump uses 5/8s male. then i get lost. I think my problem is that i dont know which is the high port and which is the return line on the control valve. Thank guys
  2. Krazy Comet
    Line with smaller fitting is the pressure port.
  3. timers
    timers Member
    richardson tx
    1974 maverick
    I got the new return line. 5/8 s fitting from the control valve to the pump with clamp. But i cant find a pressure hose? I for sure have the original pump with the cut off fitting still in it 5/8 male. And also the 3/8 fitting male still in the control valve. Cant find a hose. please help guys
  4. Krazy Comet
    Rockauto may have them, I found my hoses on ebay.
    Pressure hose is likely two piece, at least mine is.
  5. timers
    timers Member
    richardson tx
    1974 maverick
    Thank you so much. That Is It!!! I kept thinking that now im sure i remember. so cool!!!
  6. timers
    timers Member
    richardson tx
    1974 maverick
    Do you still have the link were you got yours?
  7. timers
    timers Member
    richardson tx
    1974 maverick
    Or pics
  8. Krazy Comet
    All I have is pict of orig lines. Appears both were two piece but replacement return is cut to length.
    I reused my the pump end of pressure line, that one was all but new when I bought car.
    Fleabucket pict, not sure it'll show.
