Remote Control Passenger Mirror
Discussion in 'General Maverick/Comet' started by NCFatBoy, Apr 28, 2016.
  1. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    So, for those of you that have one, what did you use for a door loom to get the cable from the door to the cabin? I see stainless door looms on ebay, but they are only 3/8" diameter which I don't think are big enough.
  2. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    If I remember correctly, the passenger remote didn't go in a loom, it's just a grommet to seal it to the door, and the jamb.
    I'm assuming you're using Pinto/ MustangII mirrors?
  3. mav man
    mav man Member
    wi
    70mav
    You can take it apart too and put a Maverick base on it be careful with cable though and control.
    cyclonewill likes this.
  4. mav man
    mav man Member
    wi
    70mav
    I just used the grommets that were on the cable already, but you could use a rubber wire protected like they use on new cars that's probably the best way.
    NCFatBoy and Paul Masson like this.
  5. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Mine did not come with any grommets. Thanks
  6. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Thank you Mav Man
  7. mav man
    mav man Member
    wi
    70mav
    I used a mirror from a full sized car so the cable controller can be mounted on drivers side.
  8. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    I believe I have Mustang II mirrors, the passenger side has a considerably longer cable controller.
  9. mav man
    mav man Member
    wi
    70mav
    Some people have made the mustang 2 mirror work but the base isn't the same,it don't sit just right though.
  10. HadaGrabberonce
    HadaGrabberonce Member
    Talcott WV
    1973 Maverick 302 C4 3.55 Tractionlok Granada disc brake conversion Small front bumper
    Did you install the Mustang ll mirrors? How did they look? I have a set for my car but I did not realize the base angle was different.
  11. stumanchu
    stumanchu Stuart
    Portland, OR
    I have a pinto passenger mirror with remote....it has two grommets on the cable and the little joystick thingie was mounted under the dash slightly to the drivers side of the middle. I can post some pics of it tomorrow. It would require holes put in the door and door jamb for grommets that the cable passes through, and one hole under the dash for joystick to mount. I thought it would be nice, but am not motivated to install it currently.
  12. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I think my Maverick has Mustang II mirrors on it. I will try to get you a pic this weekend.
  13. jasonwthompson
    Carrollton TX
    The blue car is factory sport mirrors. The white, I am almost 100% sure are Mustang II mirrors. They are mounted too far forward but hopefully you will be able to see the angle they mount at.
    NCFatBoy likes this.
  14. HadaGrabberonce
    Talcott WV
    Thanks for posting the pics. That is a noticeable difference. I think I will try to find a set of Maverick mirrors.
  15. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    That's about what I suspected they would look like. May just sell mine.
