Removing carpet cement
Discussion in 'Technical' started by olerodder, Jun 28, 2012.
  1. olerodder
    olerodder Member
    NorCal
    Will give it a try today.
    Thanks,
    John
  2. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Solvent depends on the material. You find out what the cement is then look up what solvents remove it.
    As to the ventilation question. If it is inside the car just cover up the windows if you can't roll them up and run a duct out of one of the back quarter windows with a fan pushing air in from somewhere and a fan pulling through the duct. Then put some charcoal filters on the duct. Shouldn't cost you much more than $40 and will eliminate any fear of exploding your garage.
    An overnight soak is the BEST way to remove cements.
  3. 71gold
    would just putting new carpet over it be an option?
  4. olerodder
    olerodder Member
    NorCal
    Not an option................although I'd love to put a Halon system, but just don't want to spend the $600+ for one.
    No need for carpet in a race car.............maybe if I was racing in the B/SM classes............just want to get it out and clean up the interior and get rid of the gas and oil smell.
  5. blugene
    Rhino Liner :idea:
  6. yellow75
    Tillamook Oregon
    If you mean the ones that go under the door sill plates I have a couple sets of those, most of the cars I have parted had the cardboard type so I kept the hard plastic ones.
    Send me a PM if these are the ones you want and I will figure out how much to ship them to you
    Mike
  7. Tannersg1
    Tannersg1 Member
    Classified
    Have you tried using a torch and a scraper? Might get the biggest part of it up.:huh:
  8. olerodder
    olerodder Member
    NorCal
    I want to take off weight, not add.......................if I was bucks up I'd get some Lizard Skin......................maybe later.
  9. olerodder
    olerodder Member
    NorCal
    I'd really be affraid to light a torch inside the Maverick for fear everything still left on the floor would ignite........................and I wouldn't be wearing my firesuit........................I think I'll stick with the chemicals.
    Thanks,
    John
  10. blugene
    I kinda thought so but also thought it would be about the lightest thing to apply for some sort of protection and a non skid surface.
  11. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
  12. olerodder
    olerodder Member
    NorCal
    I think there is still enough sticky stuff on the floor that I won't have any problem with skidding...........................for now I'll just keep the bare floor...................I've still got a long ways to go though.
  13. olerodder
    olerodder Member
    NorCal
