Removing emissions clutter
Discussion in 'Technical' started by Mlover, Feb 9, 2020.
  1. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    Hello Everyone. This weekend I’m removing some of my unneeded emissions equipment. I removed this tin can piece (picture attached) Do I have to block off the lines it connected or bypass the tin can and run a line from the carb to the exposed line on the firewall? Thanks!
  2. 71gold
    I would block off the lines. the metal line runs back to the gas tank.
  3. Krazy Comet
    That line has to "breathe", if blocked the fuel pump could just quit pumping due to vacuum building up in tank. Occasionally tanks collapse from vacuum.
    I consider emissions clutter the snake pit of vacuum lines, EGR valve etc. I'd leave the charcoal canister in place. Currently my Comet doesn't have one, but I do have cannister from parts car I'm gonna install.
    TeeEl and BBMS18 like this.
  4. 71gold
    "That line has to "breathe", if blocked the fuel pump could just quit pumping due to vacuum building up in tank. Occasionally tanks collapse from vacuum."
    true...but being a "vacuum" line it is sucking dust and dirt from in the engine bay. I think it best to cap line and install a "vented" gas cap. or as I did, install an inline filter at the gas tank.
  5. m in sc
    m in sc Member
    rock hill sc
    i actually stuck a breather vent in the end of the line after i pushed it though the old canister bolt hole in the fender well
    Rasit and TeeEl like this.
  6. TeeEl
    TeeEl Senior Member
    Colorado
    I removed my canister decades ago and wish I still had it...
  7. m in sc
    m in sc Member
    rock hill sc
    I dont mind the canister but mine was cracked and looked like hell on top of that. But i agree, the line should be vented if its there, it wont hurt and its a good backup if the fuel cap vent fails. (been there on another car)
  8. TeeEl
    TeeEl Senior Member
    Colorado
    Do you have a picture of where it connects to the vent hose?...
  9. m in sc
    m in sc Member
    rock hill sc
    I just threaded it into the end of the rubber line. (actually used a smaller one that pictured). I work for the company that makes/sells those to fastenal, msc etc..
  10. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    Thanks for the input everyone. I didn’t take a picture because I didn’t think I would be reinstalling the piece. Does anyone have a diagram or picture of how to properly connect it?
  11. Craig Selvey
    Won't you need this stuff to pass a California inspection?
  12. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    For like a smog test? It is exempt.
    Lost my canister cap and carb/air filter screw. I ended up ordering a breather vent cap. I will run it through the fender as suggested.
    thank you everyone!!
