Removing the column proves difficult
Discussion in 'General Maverick/Comet' started by Hairy W Bush, Nov 16, 2019.
  1. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    I have the front end off the ground So i can rotate my bolt access, but I cannot for the life of me get enough leverage on my wrench over the rag joint. All the pipes I have won't work for my tight work area. What do?
  2. Krazy Comet
    For rag joint bolt, I always use a 12 point socket and a couple feet of extensions.
    Just pulled the Fairlane apart last month to convert to P/S, no issues.
  3. Hairy W Bush
    Hairy W Bush Member
    Georgia
    Where did you put the socket? I just rounded one of the bolts with a wrench. I can't get a socket wrench to work nor the wrench attachment for a socket wrench.
  4. Krazy Comet
    Are you referring to the two bolts on upper part of coupler(I use box & ratchet wrenches on those) or the single bolt that connects joint to steering box? For that one, remove bolt as I prev described and the coupler should remain on column during removal. Note on reinstall there is one large spline that must match same on shaft when reassembling.
  5. Hairy W Bush
    Hairy W Bush Member
    Georgia
    The 2 bolts like you mentioned.
    It's very tight in that spot and the wrench is practically against the backo the cylinder head. My steering column no longer locks so I had a relative try and turn the wheel opposite way of my wrench. Nothing accomplished today.
  6. Krazy Comet
    Well I dunno what to say, I had one out of my Comet when rebuilt front end.
  7. Hairy W Bush
    Hairy W Bush Member
    Georgia
    well damn this isn't good.
    if I remove the single bolt that connects the joint to the steering box, will I be able to pull the column at least up to where the joint touches the firewall??
  8. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    If you remove the whole firewall plate it will come through no problem.
    On the rag joint bolts, I believe the bolt uses a 1/2 inch wrench and the nut is 9/16. What size were you using? Might not be stripped just need the correct size, I have made that mistake before!
  9. Hairy W Bush
    Hairy W Bush Member
    Georgia
    Oh duh. I should just undo the bolt in the box and it all comes through? Ok. Yea I have the plate unbolted. I wanted that off and to do that the column needs to move.
    I used a 1/2.
    RMiller likes this.
  10. RMiller
    Kennewick, WA
    Yep, the hole in the firewall is pretty big so it isn't an issue.
  11. Hairy W Bush
    Hairy W Bush Member
    Georgia
    Hey guys, which single bolt are you referring to? I'm at the car and the bolt I was thinking was just a plug for grease...
  12. RMiller
    Kennewick, WA
  13. Hairy W Bush
    Hairy W Bush Member
    Georgia
    Got it! Letting the penetrant sink into it now. I have a new joint while I'm at it.
  14. Hairy W Bush
    Hairy W Bush Member
    Georgia
    Ok that bolt is out, buy the column still only wants to move about half an inch and stop. I've got a long prybar prying on that collar and it still won't budge. Am I doing the right thing here and it's just stuck?
  15. RMiller
    Kennewick, WA
    Where the bolt goes through the coupler is split, get that to the top and spread it apart a little bit. That will free it up to slide off. You can put something in and twist or tap a chisel in it. Don't beat on it too hard or you can damage the bearings.
