Removing the column proves difficult
Discussion in 'General Maverick/Comet' started by Hairy W Bush, Nov 16, 2019.
  1. Krazy Comet
    Coupler should just slide off.
    When swapping to a '74 Comet P/S sector, I didn't have any issue removing one from my '69 Fairlane or installing one on the Comet box. Note bolt must be removed, not just loosened.
  2. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    Alright I've had it off now. I used a torch and penetrant. My next question is, does this look right?
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Yep, that's the way mine is too.
  4. Hairy W Bush
    Hairy W Bush Member
    Georgia
    That's strange.
    I have a huge 1973 Chilton's manual that has guides for all auto makers, but it doesn't cover a rag joint/column...
    It this thing hard to get back onto the box shaft? They tell me to just lightly tap it on with a socket so I think I'll be ok.
  5. RMiller
    Kennewick, WA
    It needs to be lined up properly or it will not go on. there is a spot where the splines are wider to clock the coupler.
