removing the zbar
Discussion in 'Technical' started by Hairy W Bush, Sep 7, 2015.
  1. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    I need to get my header out and I'm trying to remove the z bar. I got the adjustable pushrod out and that's it. what's next?
  2. tody
    tody Member
    cologne, germany
    zbar should have a center bolt, take it out - then you should be able to remove the frame side.
  3. Hairy W Bush
    Hairy W Bush Member
    Georgia
    what's holding that? I can't see so what should i look for. unless you mean the clip and spring by the firewall
  4. dyent
    dyent Member
    vancouver bc
    V8 z-bar is 2 piece unit that is held together by a 5/8" head bolt, once removed frame side half should come off frame side bracket. The engine side is held onto the ball end stud by that spring clip, so it has to be removed and then that z-bar half will come off the engine ball stud. The 2 nylon bushing halves should stay on the ball stud, as they are cupped around the ball itself.
    David
  5. Hairy W Bush
    Hairy W Bush Member
    Georgia
    im a little confused dyent. the bolt is off and i do not see this "spring clip" holding the bar to the engine. it looks like it'll just fall off as soon as i get the other side off. the frame side bar is unclipped from the pedal rod (bushing is worn out) and it's still attached. what is holding it to the frame?
  6. dyent
    dyent Member
    vancouver bc
    there is a frame bracket, that has a stud/round bushing, bracket is attached to frame rail with 2 - 9/16" head bolts. If both upper and lower rods have been disconnected from the z-bar, along with bolt that holds the 2 halves together, should beable to remove z-bar from frame side. There was a write up a couple of months ago regarding another member's z-bar and I will try and locate as he had pictures.
    Perhaps in your situation, you may have to loosen/remove frame side bracket in order to remove the z-bar, it's a real pain in the butt to get access to those 2 bolts, especially if you have headers.....good luck!
    David
    http://mmb.maverick.to/threads/equlizer-bar-fix.103527/
    see #4, picture of z-bar and engine ball/stud/bushing....
    http://www.1bad6t.com/Maverick/repair/exploded_views_trans-axle.html
    see clutch/pedal assembly for your year, shows Ford Service Manual diagram for the z-bar
    http://mmb.maverick.to/attachments/melvins-jpg.96152/
    better view of engine side bushings.......
  7. Hairy W Bush
    Hairy W Bush Member
    Georgia
    look in the 2nd link. in the middle of the diagram, to the right. it looks like somehow there's just 1 bolt holding it on. (not the halves bolt) where is it??
  8. rthomas771
    There are 2 bolts on top of the frame rail.
  9. dyent
    dyent Member
    vancouver bc
    are you trying to access those bolts from the topside or from underneath? especially with headers, easier to gain access with car up on good set of car ramps, crawl under and bracket/bolts are just behind the steering box. (between the box and firewall along top of frame rail). should beable to access with short box end 9/16" wrench, like I mentioned in earlier post, pain in the butt. also use safety eyewear to prevent all the crap from falling into your eyes........
    David
  10. rthomas771
    If you're crawling under the car...it's easier to reach the bolts with your feet sticking out under the front bumper. With your feet sticking out from under the driver's side door you cant reach the bolts as good. This is if you're right handed. If left handed...you are on your own.
  11. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    1970 Maverick Grabber 200/six, swapped to 306ci
    Can a clutch Z-bar be used on a C4 302 application?....if not I have one for sale.
    If the bar mounts in the same place as the 200-C4 setup, I pulled mine with a socket and long extension.
    With the 306 already in the car, the engine head pushed the bar back....forgot to take off...quite tricky, but possible.
  12. rthomas771
    Automatic transmissions don't use a z-bar. If you have a manual transmission z-bar...I'm interest in it.
  13. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    Thomas,
    I do have a clutch Z-bar, could use the money to get my accelerator cable and shift cable.
    Those are the 2 main items stopping me from rolling under power.
  14. Hairy W Bush
    Hairy W Bush Member
    Georgia
    WOW, I got everything out. the first bolt at the front is next to impossible. from underneath you got the header in the way, loose or not. from up top even with a swivel joint, it's hard to get the extensions on the bolt. i'm done.
    now, I need to rebuild the assembly with everything.
    I see this http://www.ebay.com/itm/Bronco-Cougar-Fairlane-Galaxie-Mustang-Torino-Maverick-Clutch-Rod-Bushing-New-/371427473371?ssPageName=STRK:MEBIDX:IT&_trksid=p2047675.l2557&nma=true&si=2EBRWTZOW4DSlweL%2Ff03acLkyjU%3D&orig_cvip=true&rt=nc
    how many would I need and where else can I get this?
    dyent posted this http://mmb.maverick.to/attachments/melvins-jpg.96152/ but I don't see where those little clips go...
    so is there a 1 stop kit for this?
    also I think my clutch fork pushrod is worn at the ball shaft and I can't find that. might just try welding it back up.
  15. yellow75
    Tillamook Oregon
    I have always taken those bolts out from the top side using a wobbly on the extension with some tape wrapped around it to keep it from moving so easy, practice and patience are needed though.
