removing the zbar
Discussion in 'Technical' started by Hairy W Bush, Sep 7, 2015.
  1. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    alright i'll just need the top part of your list then. it's everything from the end of the rod that comes out the firewall (zbar attach point) on down. i just need the clutch fork swivel btw but I know which one that is.
  2. dyent
    dyent Member
    vancouver bc
    Melvin's has 2 different versions, one with the threaded hole and one without.......
    D1DZ-7A528-E w/o threaded hole
    D1DZ-7A528-T threaded hole
    both are same price at $14.95
    Melvin's great people to deal with, good luck!
    David
  3. rthomas771
    I used the threaded idler swivel along with jam nuts
  4. tody
    tody Member
    cologne, germany
    so did i.
    while sorting out my clutch issues, though i found some message board postings adressing this point. they claimed to use the un-threaded swivel with two jam nuts one one side (towards the fork). reason stated was that the clutch rod would be able to move and swift a little and would be subject to failure otherwise.
    in the ford master parts catalog, the drawing is a little unprecise in this area, so i can't quite make it out...
    rthomas771 likes this.
  5. rthomas771
    I guess you can call it a little insurance policy because locking jam nuts do wear out the more you turn them. More threads more the merrier
  6. Hairy W Bush
    Hairy W Bush Member
    Georgia
    rthomas you welded up the whole hole right and not just the half that was worn?
  7. tody
    tody Member
    cologne, germany
    weld it up completely, otherwise you wouldn't be able to drill the new hole precisely enough.
  8. rthomas771
    Tody is correct...I welded the whole hole. I used a cereal box to trace a template to know where to re-drill.
  9. Hairy W Bush
    Hairy W Bush Member
    Georgia
    I'm going to wait till I get the bushing in so I know the size.
