Replace drums or swap to disk?
Discussion in 'Technical' started by Lunchboxjr, Feb 6, 2012.
  1. baddad457
    The rotors have a minimum thickness cast into them, bring a set of dial calipers to measure them. Minimum is something like .920 If the calipers are still painted, they're likely still good. I recall one set I bought had everything nearly new and paid $75 for the whole setup.
  2. Lunchboxjr
    Lunchboxjr Member
    Bay Area, CA
    1971 Ford Maverick
    Thanks for the info! If I can save some money doing it this way, I will be able to pick this up also
  3. baddad457
    I'd look at a kit that's also got new upper control arms too. So much easier to just unbolt the arms and bolt up the new ones. The old ones don't get any stronger with age either.
  4. Lunchboxjr
    Lunchboxjr Member
    Bay Area, CA
    1971 Ford Maverick
    any suggestions on a better kit?
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Google scarebird, I think they have a kit that works for four lug wheels.
  6. Acornridgeman
    Wisconsin
    Totally agree ....... :thumbs2:
    Here is a kit I've used from Laurel Mountain Mustang. The kit I received had very good steel and was made here in North America (Mexico I think). Watch out for any kits that have Chinese steel. Ask the salesman before you buy where the parts are made. I've had Chinese bolts on the upper control arms twist off like butter 20 ft lbs before full torque. Do not buy Chinese kits.
    http://laurelmountainmustang.com/products/1968-1973-mustang-master-front-suspension-kit
    Full kit - $264
  7. Lunchboxjr
    Lunchboxjr Member
    Bay Area, CA
    1971 Ford Maverick
    Thanks man! with the kit listed, would I need anything else?
  8. Acornridgeman
    Wisconsin
    As long as your strut rods, sway bar and springs are good, the only other thing to buy is a set of new shocks. Plus whatever you decide to do about the front brake project. Oh.....and a front end alignment when you put all the new stuff in.
    :drive:
