replacement gas tanks
Discussion in 'General Maverick/Comet' started by Rickringo, Sep 4, 2010.
  1. j miller
    Polson, Mt
    rock auto sells them too. i put a 75 tank in my 71 with no clearance issues and used the same straps with longer carriage bolts. the only issue i had was the sending unit was not accurate for the tank.
  2. Rickringo
    Rickringo Member
    Houston, Texas
    1975 Maverick 2 door, 250ci.
    How did you solve the sending unit problem? Mine is shot.
  3. rthomas771
    I bought my tank from Rock Auto and the sending unit that came with my tank is accurate enough not to be stranded without gas. Might not be as accurate as a newer car. The gauge goes past F when it is full and goes to E with 1-1/2 gallons of gas left in the tank.
  4. j miller
    Polson, Mt
    thats what mine did too. when full the arrow will go past full. empty is just below 1/4 tank. i didn't fuss with bending the float to be more accurate. it is close enough for me and won't leave you stranded.
  5. 71gold
    i set my float so as to have 2 Gals. on empty...:thumbs2:
  6. mojo
    How did u go abt determining where to set the float so that u new u had 2 gals. B4 empty? How many gals does tank hold? My tank is orig and im trying to get a jump on details of a replacement. Thanks.
  7. 71gold
    I put 2 gals. of gas in the tank...the reading was just off empty. I jacked the car up on the driver side and pulled the sender...adjusted the float and sat the car back down. once i got it to read empty (first try) I was set...:thumbs2:
  8. mojo
    Thanks, for that info. I am putting this on paper or I know I will forget it.
    BTW - That is 19gal tank?
