Retrofit roller options
Discussion in 'Technical' started by Decurion, Oct 26, 2008.
  1. baddad457
    I'll bet they're made in China. That's where all the other cheap copy cat parts are being manufactured
  2. Decurion
    Decurion ....huh?
    Livonia, MI
    65 Comet, 65 Falcon, 01 Fosuc
    No response from either seller, guess Ill fork out the big bucks for a name brand set, unless I get lucky and find a set used.
  3. bmcdaniel
    Reduced base circle cams can bend and twist with high rpm and stronger than stock springs. The best, though more expensive way, to put a roller cam in a non-roller block is to use a full-sized cam, not a reduced base circle, and Crane link bar lifters. They are a drop-in affair. No drilling required and you can use the lifters in any block, even a roller, and they will out-rev the OEM lifters.
    If someone put an E cam in a non-roller block with stock lifters and hardware and had no oil pressure issues they are extremely lucky.
  4. scooper77515
    How "pre-roller" are you talking?
    I put roller rockers, lifters, dogbars, spiderbones, etc. (or whatever they are called) in my block but they were on an 88 model "pre-roller" block. They had the two nipples (heh-heh!:bouncy:) in the lifter valley that would allow me to drill and tap a couple screw holes to mount the spider bar doohicky thing-a-mabob.
    So if it is a "302" block, I am of no help, but if it is a pre-roller block with the nipples, you should have little problem adding the roller stuff to it.
    My cam DID have a smaller base-circle but only on the exhaust valves, to give them extra lift, and I used lash caps to take up the slack. It is a fairly wild cam, though.
    A moderate came should be able to fit in there without it.
  5. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I used the Crane link bar hydraulic rollers in my 77 Mustang II with an E303. These are pricey at $500 set, but much better than running a reduced base circle cam. With the Crane lifters, you can run any standard hydraulic roller cam, whereas you are limited in grind choices going with a reduced base circle.
  6. baddad457
    Your block is a roller block regardless of what cam Ford originally had in there. There were no non roller blocks made after 1985.
