Rims
Discussion in 'General Maverick/Comet' started by Maverick_Ian90, Nov 14, 2018.
  1. CaptainComet
    71 Mavrk,
    Could you please share tire and wheel sizing and offset. Looks good!
  2. 71Mavrk
    71Mavrk Member
    Nevada
    Thanks everyone.
    American Racing 500 17” wheels and Michelin Pilot AS3 235/45/17 tires.
    I dug through my stack of receipts for the build. I could not find the wheel receipt. I think they were 4.5 BS. The fronts are very close to the lip but no rubbing. If I were to do it again, I would roll the lip or use 1/4 more BS.
    Tires are the same diameter as stock. No need to adjust the speedometer.
    Micah
    http://mmb.maverick.to/resources/my-1971-maverick.221/
    Russell and CaptainComet like this.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    They just raised the price on those wheels by $100 each. Pretty drastic.
  4. greenwa1
    greenwa1 Member
    El Paso Texas
    72 Comet GT, 71 Maverick
    Is that 17x7 for the rim size?
    I was reading in your build that if you had to do it again you would have rolled the fender lip or added another 1/4 more back space, 4.50 to 4.75. Would that be only for the front?
  5. 71Mavrk
    71Mavrk Member
    Nevada
    Yes, the rear is just fine but if you want to be able to rotate your tires, you would want to change them all. I think there is enough clearance for the rear springs. I may bring my ride height up about 1/2" in the front. I like how it sits now and it has not hit the fender, but just to be safe. Plus my exhaust is a little low. When she goes in for her next alignment, I may do it.
    Micah
    Russell likes this.
  6. CaliMaverick72
    CaliMaverick72 Member
    California
    1972 4 door Maverick
    What about some four lug options? They are more difficult to come by. Has anyone here used four-to-five lug adapters?
  7. CaptainComet
    Be super-careful when shopping for 4 lug hardware. Ford used two different sizes in the 1970s. These and early Mustang were one bolt pattern and Mustang II and later are a different size.
  8. Shorty
    Shorty Member
    Lafayette, In
    I used a set of wheel adapters on my 1st Maverick and I never had the slightest problem with them. If you do use them just be sure you install them correctly, to proper torque and re-torque after a couple of hundred miles running.
    Bruce
  9. CaliMaverick72
    California
    Thanks for that info guys.
  10. RustyBucket
    RustyBucket Member
    denver
    1974 maverick 302
    https://www.jegs.com/i/Coker-Tire/257/6880830/10002/-1
    Anybody running these Goldline for their Mavs >? Im thinking of 17x8 rear and 17x7 fronts and havent modded anything as of now. Front rub is my concern..
    Thanks >>
  11. palser64
    palser64 Member
    Barboursville, WV
    1977 maverick , 1973 maverick, 1973 maverick, 1971 maverick grabber, 71 comet, 74 comet
    255/70/15 stuffed in the fender wells....
  12. maverick600
    maverick600 Member
    San Angelo, Texas
    What are you running in the front?
  13. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    These are US mag 17X8 and 17X7. Tires are Kumho 255/50R17 and 225/45R17.
    1/2" drop on the rear and ~ 3/4 coil cut out up front.
    BBMS18, CaptainComet and Shorty like this.
  14. maverick600
    maverick600 Member
    San Angelo, Texas
    Ok I need an expert. An 18" rim, 7.5 width with 46mm offset, what does that correlate to backspace?
  15. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
