Roger's Idiot thread for a 302/C4 into a '70
Discussion in 'General Maverick/Comet' started by smegnl, Sep 18, 2019.
  1. Krazy Comet
    The factory did use port pictured but no way I'd use it for PCV. Original engine in my Comet had a lean misfire on #7 because of that hookup. cometenginerear.JPG
    RMiller and smegnl like this.
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Good point, didn't think about it leaning out that cylinder.
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  4. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Agree with RMiller. The one on the left looks to be a broken temp sending unit, though Ford usually put those at the front of the engine. No reason you can't use the vacuum tree shown. I suggest you turn your PCV-only carb spacer upside down, however and look at it. It should have 2 small notches which connect the internal passages of the hollow spacer to manifold vacuum. On this pic they're roughly at 5:30 and 6:30 positions.
    I too would do without the EGR valve. It's ugly and they do go bad.
  5. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    It does. however the end of it is solid. See tow pics below
    [​IMG][​IMG]
    Jaybee likes this.
  6. Krazy Comet
    PCV should be fed from combination of vac from both banks of the engine. That's what the openings in spacer does.
    Where is the EGR port in intake? Would it be blocked off if your solid spacer were installed upside down? If so, could you possibly drill the spacer and use it?
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Made a block of plate in the schools robotics lab.
  8. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  9. Craig Selvey
    I find that the exhaust will burn right thru the gaskets on the block off plate.
  10. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Huh...that's mighty peculiar.
  11. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    so what do you suggest? Something different? The thick gasket on the bottom?
  12. dyent
    dyent Member
    vancouver bc
  13. Craig Selvey
    I would suggest doing away that spacer and get an aftermarket intake that has no EGR on it.
    mojo and Krazy Comet like this.
  14. Krazy Comet
    I once saw a '77 F-150 with a burned out aluminum carb spacer. Those used EGR intake but blocked opening with a solid spacer.
    The F-150 was introduced mostly to get around emissions/EGR requirement of F-100. Of course within two or three years the F-150 was subject to same requirement as F-100. I believe '81 was last year of F-100.
  15. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Ive looked and looked. I cant find a spacer with no EGR but with a vacuum port for PCV
