Roger's Idiot thread for a 302/C4 into a '70
Discussion in 'General Maverick/Comet' started by smegnl, Sep 18, 2019.
  1. Krazy Comet
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Here is the egr in the intake. I tried to mount the no EGR spacer upside down, but it didnt line up. Screw it, im gonna put the solid thick gasket with out a EGR hole on the bottom > the spacer > then thing gasket. Thanks everyone for the inputs.
    I gotta move on and learn about cable shifters.
  3. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    I think I have an extra 2v spacer with the hole for the PCV. $20 and it’s yours. Just let me check tomorrow and see if I can locate it. Matt
    BBMS18 likes this.
  4. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    let me know
  5. Hotrock
    Munroe Falls, Ohio
    What condition is your carburetor? That intake manifold looks pretty sad. Are you on an extreme budget, if not I would be considering a new 4V intake and vacuum secondary carburetor with electric choke.
  6. mvw66gt
    mvw66gt Member
    71 Comet GT
    Here’s a pic. This is off of a 289 2v but should work fine. Also have an extra carb to spacer gasket you can have. I won’t be able to ship it until this coming weekend as I’m headed out of town for the week. You use your thick gasket under this and then the thin one on top. You’ll have to clean it up. The pcv outlet is open on the back. - Matt
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    can I see the underside chambers? And the end is open?
  8. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    What does the exhaust port look like under the tape, is there a single round hole down inside? I had a Pontiac that had heat passages and found the closest sized freeze plag and drove it in after cleaning the port of carbon. Worked well until I was able to buy and aluminum intake.
  9. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I think its ok? I know i have to get an elect choke for it.
  10. mvw66gt
    mvw66gt Member
    71 Comet GT
  11. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Thanks. Thats not gonna work. It would put the EGR port right into the PCV. Thanks for the kind offer though and have a save trip back.
  12. mvw66gt
    mvw66gt Member
    71 Comet GT
    That is the PCV port. There’s no EGR hookup. I thought you were trying to eliminate the EGR. This was how the 65-68 289/302 did the PCV. - Matt
  13. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I am, but the channels in the back would allow the EGR hole in my manifold to exit via the PCV. If you look at post #182 you will see how the EGR hole in the block will be sucked up by the PCV. I would need one that was solid on the back (like mine) but had a PCV port(like yours). Im beginning to think thats not an animal that exist.
  14. mvw66gt
    mvw66gt Member
    71 Comet GT
    The thick gasket that goes between the spacer and the intake will seal that hole in the intake off. The PCV is then open just to the carb body. PCV function only. - Matt.
  15. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    appreciate it, but I think Ill just use my blocked off EGR Frankenstein spacer.
