Roger's Idiot thread for a 302/C4 into a '70
Discussion in 'General Maverick/Comet' started by smegnl, Sep 18, 2019.
  1. Krazy Comet
    Dismal Swamp
    If you just gave a shot down the carb, probably ran all it's going to without more gas... With float bowl filled should run 15-20 seconds. At that point, they've usually picked up gas in tank.
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    whats that, 1/4 cup? 1/2 a cup? to fill the bowl?
  3. Krazy Comet
    Dismal Swamp
    Maybe 2½ - 3 ounces to fill carb bowl.
  4. Hotrock
    Munroe Falls, Ohio
    Roger, I suggest you purchase a remote starting switch. I have owned the same Snap-on switch for years. It allows you to start your car without assistance while remaining under the hood. Great safety item. You can operate the throttle while starting the engine plus observe what is going on under the hood i.e. fuel/oil leaks!!! For an old Ford or Mercury with a remote starter solenoid it is a no brainer.
    OTC Tools 3650 OTC Heavy-Duty Remote Starter Switches | Summit Racing
    Just don't buy a cheap switch.
  5. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Sounded real promising there for a second. I think all the gas you had in the carb.
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    gonna hook it up to a gas can and try again.
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I double checked the wire order, looks right to me. Put a hose in the gas can to the fuel pump. I checked a plug wire to ground and it is sparking. I just dont know.
  8. Krazy Comet
    Dismal Swamp
    Is it drawing fuel from can & creating fuel pressure?
    Tried gas down carb again?
  9. stumanchu
    stumanchu Stuart
    Portland, OR
    When I "first started" my motor, it wouldnt stay running. I dont remember which way the timing was off, but after about a 30* change, it ran enough to put a light on it. Yours sound like the timing is off some but may run once the carb has drawn and delivers fuel. Re-fill the bowl through the vent again. I think you are close.
    smegnl and Krazy Comet like this.
  10. Krazy Comet
    Dismal Swamp
    If you have a small container with spout it's easy to fill carb bowl. Youtube's Uncle Tony's Garage did a video on using a similar bottle.
    When there's gas in bowl the accelerator pump in carb should function(one for each barrell), will stream gas anytime throttle is opened.
    mojo likes this.
  11. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Thank you, thats what I actually did yesterday. I filled it. I saw gas squirting little jet streams. It just doesnt want to fire. I think my plugs wires are right. I got spark on the #5. I think that means my module is working since I got spark? I may have to pull all the wires and check for spark.
  12. Krazy Comet
    Dismal Swamp
    Mebby it's losing spark with ignition in run? Possibly run power to module miswired? A flaky module can give same symptom.
    Need to verify it has continual spark in start & run(use coil wire to ground, 8x more sparks), easy enough for start. For run, I think you can verify by jumping solenoid(ign on). The solenoid ign wire should be disconnected for this procedure.
  13. Krazy Comet
    Dismal Swamp
    One other possibility, maybe the dist was installed incorrectly when you bought engine.
    Verify the rotor is pointing at #1 plug wire on cap with engine at TDC, possible already checked?
  14. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    Who did your wiring? Tim the Tool Man? I'd start by trouble shooting that ignition wiring and make your connections better.
  15. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I know wire nuts are not perm, once i get it to start I will solder them in with heat shrink. I did go thru all the wire nuts and make sure they were connected and well twisted. I got a spark plug light to test with. And last I checked a Cocaine trafficer and drunk driver did not wire my car
  16. Krazy Comet
    Dismal Swamp
    Couple wire nuts ain't nothing, here's how electronics experimenters breadboard a new circuit.
