Roger's Idiot thread for a 302/C4 into a '70
Discussion in 'General Maverick/Comet' started by smegnl, Sep 18, 2019.
  1. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    They do offer hose bushings. If I were to use one I would use some rubber cement and fix it to the hose.
    stumanchu and smegnl like this.
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    The group on facebook had a couple members say that they had the pan filled in a 1970. So I should be good
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    You and me both, You and me both, LOL. THANKS!
  4. Krazy Comet
    One thing for sur, that motor has probably been rebuilt. It's repainted the WRONG color(rebuilders often did that). The proper color Ford blue is similar to the tarp it's setting on, was color used from '66-'80, reguardless of engine size.
    Also the vacuum switch is painted, Ford never painted senders, sensors etc.
    Is there a number stamped on the flat pad between intake and bellhousing?
  5. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    supposedly, that engine was rebuilt 40K miles ago. Im gonna start tearing it apart to do some painting and cleaning. No rebuild. Ill let you know if I come across a stamp number.
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I started to clean my eBay parts today? I swear these things must have been on a 4x4 maverick...
    BBMS18 likes this.
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    any suggestions on a distributor and cap? I dont need a top of the line megatron distr. Oh and id like it to be red. Im not sure what to look for.
    PS. I started to take off the big stuff...
    Maverick Dude likes this.
  8. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Mallory distributors have red caps.
  9. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Unless you’re going to be racing Fords Duraspark distributor that came with your 1979 302 will be just fine and you can get red caps for them.
    https://www.summitracing.com/parts/dui-32100rd/make/ford
    jasonwthompson and Hotrock like this.
  10. Hotrock
    Munroe Falls, Ohio
    I'd run the Dura Spark system, it adds to the cool factor. I spin mine to 6500 rpm over and over again with no problem. My genuine Motorcraft module has been in service for over 25 years. How many aftermarket units can do that?
    I personally like an understated engine compartment. To me big flashy items like distributor caps or shiny hoses detracts from the experience. Components should complement one another, not stand out.
    I should change out the red wires near the voltage regulator. I'll get around to it one of these days.
  11. BBMS18
    BBMS18 Member
    75 Comet
    I couldn’t have said it better myself (y)
    Jaybee and Krazy Comet like this.
  12. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    That does look nice and cohesive
    Jaybee likes this.
  13. Krazy Comet
    Cap is a piece of cake, used on all with Duraspark from '77-up. Continued on as late as '96 for TFI systems(my beater F-150 has a black cap). The adapter varies, early ones have clip hold down to dist, later ones bolt to dist & are not interchangeable.
    I have a Crane Hi-6 with std small cap on my Cobra. That's a far more potent system than Duraspark & I've never had crossfire issues. cometengineright33.jpg
    Jaybee likes this.
  14. mojo
    What ignition setup in this picture, don't look like DS II?
    Jaybee likes this.
  15. Krazy Comet
    It's not a DS, box is a Street Fire which is sort of a baby MSD 6AL.
    Jaybee likes this.
