Roger's Idiot thread for a 302/C4 into a '70
Discussion in 'General Maverick/Comet' started by smegnl, Sep 18, 2019.
  1. stumanchu
    stumanchu Stuart
    Portland, OR
    Cant find those pics.....maybe nightmares? I thought I saw a lot of them back when I went through that install.
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I had one of those brackets on the Mustang, and it did pull the two rivnuts loose from the frame. Lowering the slave piston applies more leverage on those bolts. I put some 289/302 headers on the 351. The exhaust shop had to cut and angle the collectors down to clear part of the frame, but the headers were about an inch from the bottom of the car and did not need the drop bracket.
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Cleaned it up today. now to take apart and paint. Im sure Ill have some questions as I do.
  4. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  5. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Looks like the pivot will be close to the position of the stock shifter. If it's higher should be very little, easily covered by a boot.
    smegnl likes this.
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I got some hooker 6901 ceramic coated headers. Started looking for bolts to put these on. Are all 302 header bolts going to fit? Did the holes change throughout the years of the 302 at some point? is there any special kind of bolt supposed to use with ceramic coated headers?
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Do they make a plug for this?
  8. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Remove the bolt, measure how much thread is protruding and buy one that is that length. Put the sealing washer on it and run it in.
  9. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    dont have to worry about melting the rubber sealing washer?
  10. RMiller
    Kennewick, WA
    There is no rubber washer, the metal washer under the bolt head is the sealing washer. It's like a brake line and is probably a brass washer.
    Krazy Comet likes this.
  11. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    thank you so much for taking the time to answer my stupid questions
  12. RMiller
    Kennewick, WA
    I was always told the only stupid question is the one not asked. It's the only was to learn what you don't know.:thumbs2:
    mojo, BBMS18 and smegnl like this.
  13. Krazy Comet
    Dismal Swamp
    Those heads are low compression smoggers, a set of Mustang/Truck E7TE from a '87-up would give a noticable increase in power. Should be a easy find as most of the Stang guys have upgraded.
    jasonwthompson and smegnl like this.
  14. jasonwthompson
    Carrollton TX
    I have a set, but shipping from Dallas would not be worth it.
  15. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    What do I need on the ass end of the tranny to get it to bolt to the cross member? How to get the tail to bolt to this..
