Roger's Idiot thread for a 302/C4 into a '70
Discussion in 'General Maverick/Comet' started by smegnl, Sep 18, 2019.
  1. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Thank everyone so much...I know it was a lot of questions about this Duraspark 2
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    is this Maverick specific? Everything Im finding is for a Muastang / Torino / Ranchero
    Never mind. Found one
    https://www.summitracing.com/oh/par...tions/make/ford/model/maverick/engine-type/v8
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    are there two cross members (not counting the transmission one) on the V8 Maverick? I have one like this one that goes up front. But is there another one I'm supposed to have back near the motor mounts, under the shock towers?
  4. Craig Selvey
    Only one cross member. It goes between the shock towers. Nothing up front but the sway bar.
  5. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    So the one in the picture goes between the shock towers under the car?
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Correct, it mounts behind the lower control arm mounts.
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Thanks. I think I was getting it confused with the front sway as I read it should be upgraded in size when going V8.
  8. RMiller
    Kennewick, WA
    I would upgrade it regardless for the improvement in handling. For as long as I have had mine I have never actually driven a Maverick but I'm sure they are very ill handling compared to even the worst new car. I know my Torinos and even my GTOs were poor handling cars, they rolled in corners and wallowed down the road. Comfortable but not confidence inspiring!
    smegnl likes this.
  9. William623
    Orlando
    1973 ford maverick grabber
    ou don’t have to but it certainly helps. There was a factory 7/8” bar but those are hard to find. Otherwise there is an aftermarket option. It does help with handling. I have a factory bar on my car and Love it.
    smegnl likes this.
  10. satchelmcqueen
    satchelmcqueen Member
    north georgia
    I just finished my 70 302 conversion. Check me on youtube on the video series ive done on my car called Project Woooo! It covers a lot and also the engine swap with trans.
  11. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Thanks will do
    satchelmcqueen likes this.
  12. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Built my harness today....
    Hotrock likes this.
  13. Hotrock
    Munroe Falls, Ohio
    Nice work. Your harness is very long. I don't recall the donor harness for my Comet as being that long. I installed it years ago. Memories can fade.
  14. Krazy Comet
    Dismal Swamp
    Assuming you are using a module with blue grommet, diagram is incorrect... Coil fed should connect to opposite end of resistance wire. Coil is fed by resistor, in present configuration resistor has no purpose. Resistor is bypassed during cranking by voltage fed from I terminal on solenoid.
  15. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    thanks for the catch. I was re-using the wire feed for the coil, so it would have worked. But the drawing needs to be right incase someone else in the future reads this thread, which is one of the reasons I made this thread.
