Roll cage and sub frames
Discussion in 'Drag Racing' started by Butters, Mar 22, 2015.
  1. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Mild steel is a little heavier but easier to work with than chromemoly,& most any good chassis builder will tell you he would rather be in a mild steel car in a crash because the welds are less likely to break than moly.My car came w/ a 10 point but I added 2 bars off the front hoop going through the floor & welding to the frame behind the front wheels.My feet just felt naked w/ no support there & I knew that hitting a wall & driving the lower control arm & front wheel in the floor would`nt be to pleasing when my legs got crushed.Before I added the 2 bars the car was around 2500 lbs because it`s totally gutted,I don`t think adding 10lbs of weight is going to hurt very much.
    Butters likes this.
  2. 13Maverick
    13Maverick Member
    Ohio
    '70 Maverick, '63 1/2 Galaxie 500/XL,'94 Chevrolet 1-ton dually,'86 Suzuki Samurai rock-crawler
    Half way through my build, i started wondering about the safety. I also own '63 Galaxie and figured if I'd ever get into a wreck, I'd probably be the one driving home (until I saw the utube crash-test vid of an Impala going head-on with a newer Impala) Who would'a thought my 3 1/2 tons would loose to a recycled beer-can of a car!...anyway...I'm building mine to be a mind-f**k street car...psych out the opposition even before we line up. I was thinking of doing a double-hoop with two trunk-tubes and two door-tubes(6-point). I figured I'd run a couple's test-n-tune nights at the local strip, just to see what it'll do. After off-roading for ten years, I know better than to mess with my (or anyone else's) life. I definitely don't want to do a NASCAR type cage, but i do know about the light weight=speed factor. Would down-tubes to the front frame-horns (from the dash-knee-brace) across the shock towers, stiffen up the front-end? and for a casual week-end brawler would this be over kill as well? Is the double-tube main hoop too much weight (I considered the placement behind the door windows to be the best position) for weight and safety. I have watched the utube vids of the Mavericks who have rolled, and the roof never seems to cave with a single rollbar hoop. Just looking for thoughts from racers with way-more experience than i have. Thanks!
  3. Butters
    Butters Member
    Colorado Springs
    1970 ford maverick
    yep new cars are 1000000 times safer they have crumple zones that take the force out of the impact. I'd say it's all how I makes you feel, the front frame bars will stiffen it up but my comet i had didn't have them and had a 12 point cage it just pulled the front wheels and went didn't even attempt to twist. It did have a ladder bar coil over set up in the rear though. I'm building mine with a 12 point cage also but I'm doing cal tracs and leafs on a 9 inch. Should be fine. It's all what makes you the driver feels comfortable and safe.. mine doesn't need to have a 12 point cage it's only going to go low 10s. But that's just what will make me feel safe.
    13Maverick likes this.
