Roller cam
Discussion in 'Technical' started by oddball4door, Feb 3, 2004.
  1. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    You do not have to have a reduced based circle cam. YOu can use the standard hyd. Roller cam if you buy the link bar hyd roller retrofit lifters made by crane :) I have always had to buy custom length pushrods when using roller rockers and aftermarket heads.
    I like the crane 1 piece hardend. .080 wall thickness. Good Luck
  2. Mavaholic
    Comp Cams will grind any of their roller profiles on a small base circle. Then get it through Summit and it dosent cost any more than a standard roller cam. Thats the route I went.
