Roof insulation?
Discussion in 'General Maverick/Comet' started by YellowStangDuan, Apr 6, 2014.
  1. Bryant
    mo put rattle trap in his car. anywhere there was heat the tar or what ever is in it ran out from it
    ive put peal and seal in several cars and have not had this happen with it.
  2. blugene
    This is the kind of proof I like to see..
  3. Bryant
    thats why i posted it.
    its nasty stuff. i cant imagine trying to remove or clean it up.
  4. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    I would get a couple of rolls of hvac ducting tape and covering over the mess.
  5. Cruzin Illusion
    1972 Grabber
    This thread has helped me make my decision. Thanks for all the feedback. I am gojng to go with dynamat xtreme and dynaliner over the dyna mat xtreme on the roof.
    I know everyone has an opinion and mah not agree but the information that came out in what was posted very helpful.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    If I had it to do over, I would use this stuff:
    http://www.automotiveinteriors.com/HEAT_SHIELD.htm
    A little glue, and the headliner bows will hold it up there just fine.
    There's no need to stick stuff (like Dynamat, Peal & Seal, etc.) to the roof of your car. Not to mention if you ever needed to remove that stuff, it'd be a lot of "fun".
  7. rthomas771
    I know from experience that you don't want something thick behind the headliner and still have the correct factory look...it makes the bows/seam disappear, unless the edge of the padding/foam is about 4"-6" from the bows.
  8. blugene
    Stuff looks good. But I personally wouldn't call it a sound deadener. It says both deadener and sound insulator. More of an insulator than a deadener imo. Looks like excellent stuff to use if you have a vinyl top.
  9. Cruzin Illusion
    1972 Grabber
    How much space between the bows and the roof?
  10. 71gold
    what ever the mat smashes down to...1/8th. in...:huh:
  11. blugene
    I remember maybe an inch.. My matting had fallen so I am not sure if it was touching the bows when it was first put in.
  12. Cruzin Illusion
    1972 Grabber
    I was wondering what thickness of dynaliner I should get without interference with the headliner when I get it installed.
  13. blugene
    Someone I am sure can tell you for sure of the measurement. If you have the bows you could verify it.. Mine are fed through a liner or I would put them in and measure it for you..
  14. NICK DOMINICK
    Burke, Virginia
    I just bought the 1/4" dynaliner because the 1/2" would be too thick.
  15. Cruzin Illusion
    1972 Grabber
    Thank you! That is exactly what I needed. Working on the road doesn't allow me to go out to the garage all the time to get my answers. Thanks for your help!
