Rotating Assembly
Discussion in 'Drag Racing' started by riporter, May 24, 2005.
  1. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    Price must vary from shop to shop and part to part.
    Most i've seen, whether they were put in the side or the top of the counterweight, were welded in.........that thing spins pretty darn fast!!!!
    Hey Rick, refresh my memory, is all this going in a stock block??
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Can you imagine a hunk of Mallory getting loose at 7000 RPM! :eek:
  3. don graham
    i don't like to think of a hunk of anything getting loose at 7000 rpm.:)
  4. riporter
    riporter Member
    Charleston S.C.
    Hey ! Hey!...lets don't even go there:tsk: ...that stuff weighs so much it would wipe EVERYTHING inside that block out if not the block too.:49:
    Stephen it's going in the 408, which is an Ford 351W SVO, 4 bolt inner mains, siamese bore block.
    The crank is drilled and reamed and mallory pressed in, according to the shop it works better than brazing 2 dissimilar metals and risking a fracture. He said they've been pressing them in for 10 years now to his knowledge have never lost one... he couldn't say that for brazing.
    I could have saved some confusion by saying off the bat this was a neutral balance assembly.
  5. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    those pistons look like they can handle a big lift cam...looks great
  6. riporter
    riporter Member
    Charleston S.C.
    The pics were taken after the balance, they need the total weight of the rod and piston assembly to get a bobweight.
    I'll get the spec sheet that came from Comp on the cam, off the top of my head I'd say it's gonna be pretty grumpy, 750+ hp at the crank and 7400 rpm's on the top end.
    Flow numbers on the heads ended up being 355/280 cfm. We had to have the flow numbers before Comp could build a cam
    The goal is to propel a tube chassis Mav or Comet to under 6 seconds in the 1/8th....naturally aspirated :16suspect
  7. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    my brothers 331 stroker internal balance cost around 350.00
  8. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    <--- internal balance = $450
  9. riporter
    riporter Member
    Charleston S.C.
    Derrick the rods and bolts were around 650, with your connections you should pay around the same or maybe a little less, you don't even want to think about paying retail :eek:
    The crank is an Eagle 4340, special order from Keith Craft because it's knifedged, retail expect to pay 850 with shipping, I paid 675.
    Total cost so far from pan to carb and balancer to flywheel with machining is pushing 8500. this doesn't include assembly, electronics or the headers that will have to be custom made.
  10. Maverick Man
    California
    hum thanks...
    rods were next on my list of things to collect then the crank... got something to think about... and money to save.. :rolleyes: i haven't really asked or priced around besides looking at catalogs and summit. and your right! heck no do i wanna pay retail! :coco: well unless that tree outsides starts growing ben franklins soon! :D
    whats your eta on getting this thing done?
  11. riporter
    riporter Member
    Charleston S.C.
    Finally got the specs, Comp cams custom grind, 275/275 i/e and 629 GVL, power band 2600-7800 rpms.
    We are making some progress...notice the Pro Magnum rocker on No. 1 cylinder, the pushrod hits the backside of the rocker fulcrum at TDC, hence the Crane Gold rocker laying in the lifter valley, it clears fine.
  12. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    nothing prettier than a new motor.
    so shinie.
  13. CometGT1974
    Western NC
    74 Comet GT
    Sorry, I forgot......what heads are those?? I'm running the crane gold rockers and i've had good success with them!!(y)
  14. riporter
    riporter Member
    Charleston S.C.
    Stephen there TFS Twisted Wedge "R" series heads, they were ported and polished by hand and flow tested, numbers ended up 355i/295e cfm's, note the offset on the number 7 piston cut...dead giveaway it's a twisted wedge head.
  15. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Yeah, it should clear fine laying in the lifter valley. :biglaugh:
    Motor is looking good Rick, how long from fire-up time?
