Rough idle, no third
Discussion in 'Technical' started by PAINTANK, Nov 9, 2009.
  1. PaulS
    Lead (like from a 22 bullet) doesn't form a chemical attachment to Aluminum with heat.
    I know someone said they soldered an Aluminum radiator and it worked but if that is true they didn't use the same kind of solder that is used for brass, tin and steel.
    Good luck with your repair.
  2. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Uh oh...then I need another plan. I was going to sand the area down and melt some lead over it. Now I may need to use aluminum? I watched "How It's Made" and the radiators were all soldered with lead I thought.
    JB Weld is looking better all the time.
  3. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Unless you have replaced it with an aluminum one, your rad is copper. To solder it, you need to get some acid flux, and acid cord solder. It is the same flux and solder used to join copper water pipes. The pin torch will work fine, you will need to first sand the area down real shiny and good with some fine sandpaper or emery cloth. Then clean it real good with ether or something like that, making sure there is no oil, not even from your hands, on the clean metal. Heat it up real good with the torch, then brush the flux on with the supplied brush, and heat again. Then start flowing the solder on, keeping heat on the piece just enough to melt the solder into the hole.
  4. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I used a "lead free" solder on my aluminum radiator, yes. Maybe I should have mentioned that... It's the type normally used for electronics, because that's what I had around. It definitely worked.
  5. PAINTANK
    1973 Comet 2 dr
    Mine is a genuine Ford product from 1972.
  6. facelessnumber
    Memphis, TN
    '71 Grabber
    You're probably fine for using copper pipe solder then, I'd think. Maybe even give the lead a try, can't hurt.
  7. ford84stepside
    Berry Alabama
    See post 18 then....
  8. PAINTANK
    1973 Comet 2 dr
    So I can use the same stuff plumbers use? Thats easy enough, thanks!
  9. darren
    OK this is starting to sound like a Jeff Foxworthy skit. You night be a redneck if ya fix your car with a bullet and a shop vac.:rofl2::rofl2:
    Not makin fun of you it just hit me as funny.
  10. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    If it is an original radiator I suggest taking it to your friend down the road and let him fix it. If it's that old and you have one leak I can almost promise you with in the next couple of weeks or months you will have MORE leaks. If it is out of the car now then now is the time to either re-rod and core it or replace it.
    clint
