rust encapsulant vs. por-15
Discussion in 'Technical' started by don graham, Jan 21, 2008.
  1. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    So with the Rust Bullet it's just a one step process?
    Por-15 recommends you buy
    1) Marine Clean
    2) Metal Ready (rust converter solution)
    3) Por-15 paint
    4) Top coat paint.
  2. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    1. Rust Bullet recommends removing all the loose and scaley rust with wire brushes and elbow grease.
    2. The next step is to clean the area of all dust.
    3. Once dust is removed, clean entire area with acetone and let it dry. I accelerated this process using an air hose with a water filter.
    4. Now, you apply one coat of Rust Bullet, let it cure, and apply the second coat. You must use two coats. I used brushes and rollers. However, you can use a spray gun.
    I have article in the tech article section on doing a trunk pan repair using Rust Bullet and fiberglass.
  3. Acornridgeman
    Wisconsin
    If you are considering using Rust Bullet - go to their web site. It is a really good one and has all the information you could ever want.
    http://www.rustbullet.com/
  4. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    One more thing on Rust Bullet. When ordering, get the Rust Bullet Automotive. It leaves a smoother finish. BTW, you can paint Rust Bullet with your favorite finish.
  5. maverickoutlaw
    maverickoutlaw Member
    St Marks, Fl
    1973 maverick
    Terry
    How much would i need to paint the floor of my car?
    ray
  6. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Refer to FAQ #3
    http://www.rustbullet.com/FAQ.htm#3
    You need to buy small cans, med. cans, and large cans. It has a shelf life of 2 years. I bought the quart and pint sizes. Buy the Automotive version.
