Rust mort and welding
Discussion in 'Technical' started by CCARMAN, Sep 10, 2023.
Tags:
  1. CCARMAN
    CCARMAN Member
    Kentucky
    1976 mercury comet
    Can you weld the steel after using Rust mort?
  2. mojo
    What is Rust mort?
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Clean the metal well and it shouldn't be an issue. You should also check and make sure you won't be creating any nasty gasses that would be poisonous.
  4. Craig Selvey
    If you are treating the rust with Rustmort.......then that metal is too thin to weld to anyways due to the rust. Cut out ALL the rust.
