Rusted section in engine compartment
Discussion in 'Cosmetic' started by Maverick Dude, Apr 22, 2017.
  1. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    I'm trying to decide how to tackle this rusted section. It's on the driver's side near the hood hinge. It's not really part of the front fender, yet I see an assembly bolt right next to it. Would it be worth it to remove the fender to get at it better or should I just grind out that section and fibreglass it. (I'm not much of a welder) Can that rusted section be removed by unbolting it? Not clear to me how it's mounted. Thanks.
    :cheers2:
    MD
  2. 73curtis
    73curtis Member
    ohio
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Once you pull the fender this is what you'll find, if you can't weld in new metal I would just leave it until you can do it right. The fiberglass will just make it look nice for the time being but where it is it will just keep rusting.
    Maverick Dude likes this.
  4. Maverick Dude
    Wow. Not good. Thanks for the info.
    MD
    :slap:
  5. 71gold
    take the top bolts out of the fender, raise it up and look under it and see what you have to fix...:huh:
