rusting issue
Discussion in 'General Maverick/Comet' started by bryson123, Dec 11, 2018.
  1. bryson123
    bryson123 Member
    california
    1972 MAVERICK GRABBER
    Good afternoon,
    My dad and I are building a maverick and have been trying to find the best way to deal with this rusting... We are thinking of just cutting it out and having someone weld in a new patch but aren't too sure about where to get the patch from etc. any help would be much appreciated!
    https://www.dropbox.com/sh/9prr0gqx5ta2vfl/AAAqUeUH4aie_8KSz4SB_JXna?dl=0
    this is a URL to the photos for some reason I could not directly upload from my computer...
  2. Acornridgeman
    Wisconsin
    Can't tell what the first pic is but it looks like someone added fiberglass mat at one time, the 2nd I see is the inner trunk drop off. A common rot spot for Fords. You can patch in sections from a donor car, but they are getting harder to find. Repop panels from an early Mustang are everywhere and can be fitted in. Either way this type of repair will require some advanced body man skills. It must be done correctly as uni-body cars are very troublesome in that back part of the car as it supports all the weight at the spring shackles. You need to be sure to find and fix all hidden rust.
    Mustang panel pic - you can buy them anywhere
  3. bryson123
    bryson123 Member
    california
    Do you know what year works for the panel to fit into a 1972 grabber?
  4. William623
    Orlando
    1973 ford maverick grabber
    Go onto Facebook and look up maverick comet restoration. Joe make direct fit panels for every year maverick.
  5. Buck62
    Buck62 Member
    Chicago IL
    1974 Mercury Comet (Base)
    Cut it, grind it, and weld in patches....
  6. mojo
    Where was that last picture taken?
  7. Buck62
    Buck62 Member
    Chicago IL
    At Duke's
  8. mojo
    Ok, looking good.
    Buck62 likes this.
  9. Buck62
    Buck62 Member
    Chicago IL
    Thanks! :tiphat:
  10. mav1970
    I replaced a lot of pieces on my 70 Maverick and was able to find good pieces from members on the board that live in the south where the parts are in a lot better shape than ones up in Pennsylvania
