Safety question--Should I use insulation on charging cable through rocker panel?
Discussion in 'Technical' started by scooper77515, Apr 10, 2010.
  1. scooper77515
    Will I even be able to get lugs to fit this and the 2/0 welding wire? The wire will be half as big around as the breaker!!!
  2. captainmack
    captainmack Quad Door
    Yes an "ancor" brand 2/0 lug will fit on that. True...if you dont have the tools to crimp correctly soldering is an option. Dude don't buy welding cable.... buy AWG guage wire if you love your car. Soldering is not good if things get hot though....and it's not to code on boats for that reason :)
  3. PaulS
    Anytime you make a solder joint you have to have a good mechanical (crimp) connection first. The solder is for security - not to make the electrical connection.
  4. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    2/0 is overkill IMO, but hey, it's your money!!(y)
  5. CometGT1974
    Western NC
    74 Comet GT
    It depends on what type of cable lug you are using.
    Quick Cable makes a solder lug that they call there "fusion" line and it does not require a "crimp", however, they are significantly more expensive than the crimp or crimp/solder type.
  6. Dfitzman
    Dfitzman Member
    Taxachusetts
    1971 Green Machine
    nothing beats a mechanical crimp because of the physical compression of the wire from the connector along with a dimple. Some higher priced cables are crimped AND silver soldered applications like 20- 60kw generators require this.
    Been building large gens and permanent magnet motors for 30 years and the crimpers we use are hydraulic or the hand types that are adjustable with large 30-36" handles for leverage. It takes a hella force to do a "proper" connection
