Sandblasting Sand...
Discussion in 'Cosmetic' started by Dave B, Jun 12, 2006.
  1. Jamie Miles
    Alto, GA
    I've had a few
    I've never seen a gas compressor before. Even the biggest one's I've seen were electric...
  2. Mavaholic
    Used one this past weekend in Maine. They are handy.
  3. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i bought one. i have seen some homemade ones, made out of a 55 gal barrel.
  4. scooper77515
    I use a couple different grades of sand, depending on the project. Most are pretty fine. I have a 60 gal, 8 hp compressor, and a small blaster from Sears. It uses all the air that compressor can make, and I still have to take breaks to let it refill. Also, with the heat here in South Texas, I put a large shop fan facing the tank, it gets too hot to touch with bare hand after a couple hours of constant running.
    I shoot in the drive way, then sweep the sand into the middle, sift it, and use it again. Eventually, it becomes just a dust and floats away. The rest, I scoop up and dump it in the empty lot...
    The neighbors LOVE it when I pull out the blaster... :evilsmile They run their cars as far down the street as possible and park until I get done :D
  5. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Baking soda in a power washer will take off pretty much anything without hurting the parent material. I haven't seen this in person, but there's no reason it shouldn't work.
