Scale weight question
Discussion in 'General Maverick/Comet' started by courier11sec, Apr 19, 2003.
  1. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    hey fordman..
    Does both your batteries run to the silenoid? or do they have different jobs? I have thought about running 2 in mine. Thanks for any info.
  2. fordman
    fordman Member
    lufkin texas
    1972 maverick
    both run to starter i run 40 locked on timeing starts very EZ useing the late model permanent magnet starter works much better then the old ford starter bolts to the old 157 tooth bell housing with no trouble helps on cool down with electric water pump & fan runs more rpm & amps with two batterys its the way to go in the texas heat
  3. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    Thanks, I will probably get another one. Let me ask you one more questions. Do you run 2 seperate cables to the starter?
  4. fordman
    fordman Member
    lufkin texas
    1972 maverick
    short ground to back of frame in front have a short cable to block grounds thru the subframe one hot to starter i used welding lead cable(copper wire) buy it at any welding supply shop forgot the number of it get some to wire the two batters & run to front short hot to inside of car off the starter for power supply
  5. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    So you ran both positive cables to the battery shut-off switch, then went with one to the starter from there?
  6. fordman
    fordman Member
    lufkin texas
    1972 maverick
    two positive to switch one to starter
  7. fordman
    fordman Member
    lufkin texas
    1972 maverick
    batterys are bolted in the frame thats why they are on each side
  8. fordman
    fordman Member
    lufkin texas
    1972 maverick
    Re: 2400lb!!
  9. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    Thanks Fordman....that is exactly what I wanted to see! And once again, "Awesome car!"
  10. Mavaholic
    Jamestown Distributors sells battery cable by the foot. They also have good prices in stainless hardware. I have bought a bunch of stuff from them.
    www.jamestowndistributors.com
  11. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    I am not sure I understand. If you have the batteries grounded in the back of the car to the frame, whats the one(ground) up front for? Thanks again for your help.
  12. fordman
    fordman Member
    lufkin texas
    1972 maverick
    you can run a ground all the way to the block i just used a short groung to frame in back if you have subframe ties one short in front to frame to block for a good groung for the electronics
  13. 1/4Mile Comet
    1/4Mile Comet Member
    Salina,KS
    Hey Fordman was just wondering what your cam specs were. In my 289 I had a hydraulic .498 intake .520 exaust lift 224 intake 234 exaust cam. It ran 12.66 at 106 with 5.43 gears and 30 in. tall tire I was going through the lights at about 6900. I switched to a solid lift cam .576 intake .570 exaust lift 255 intake 266 exaust duration. I am also going to a 1 in. taller tire and I swithched from a ported edelbrock performer intake to victor jr. Haven't had it back to the track yet hopfully this weekend. Do you think I will see any better times at the strip.
  14. fordman
    fordman Member
    lufkin texas
    1972 maverick
    i have never ran a 289 my old 302 had 289 rods .927 pin 302 crank 350 chev pistons flat top .025 out of the deck anyway the cam i run is comp cam xr 280 INT 608 242 EXH 614 248 SOLID ROLLER this cam put me in the 10.80-95(this cam is for a 3.55 - 3.70 gear i have a 3.70 28 10.5 15 tire) the victor jr lost me a 1/2 sec on 60 ft went back to the rpm dual plane 600 HP holley i only run 6200 rpm this thing makes lots of torque you may need the upper rpm with your 289 don,t over look the ram air box (4") it,s a good 3 tenths for about 125.00 this is cheap and easy 3 tenths i have found give us a up date on your trip to the strip
  15. 1/4Mile Comet
    Salina,KS
    You seriously run 3 tenths quicker with that ram air box?
