Scored a sweet deal!
Discussion in 'Other Automotive Tech & Talk' started by Jamie Miles, Jan 15, 2009.
  1. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Backspacing could fix that. :hmmm:
  2. Jamie Miles
    Alto, GA
    I've had a few
    Well, I fired it up today, man it revs like a beast! Unfortunately, my digital camera recently went AWOL, so no YouTube video. :( The EFI wiring is like basically identical to my 2.3.
    I test fitted the engine in my '73 also. It would actually be possible to install this engine with the shock towers in place. It fits between the stock shock towers with the factory manifolds removed. The exhaust ports come straight out horizontally on either side, and there is about an inch and a half of clearance between the exhaust ports and shock towers, which I don't think is enough for headers. You would need to do the Shelby drop and shave the shock towers in order to have enough room to build some decent headers.
    Down below, the steering center link is of course still in the way of the oil pan. I just left the engine sitting in the car and threw the hood back on it so it has a nice dry place to stay for now.
  3. Craig Selvey
    You do realize when you do the Shelby drop.....one is actually "raising" the mounting holes on the shock tower for the upper control arms. Is this what you meant to say? Would you be raising the mounting holes in order to get the nuts inside the engine compartment to be above the exhaust headers?
  4. PaulS
    Craig,
    The Shelby drop lowers the mounting hole by one inch. That is why it is called the Shelby "drop".
    By lowering where the upper control arm mounts the front end geometry is made to add negative camber when the suspension is loaded and increase positive camber when it is unloaded. That keeps the tire tracking on its tread in hard turns.
  5. Craig Selvey
    Thanks for the clarification Paul......I was confused (as one can tell).
  6. Dave B
    I want to see some pic's of this engine in a Maverick!!
  7. Jamie Miles
    Alto, GA
    I've had a few
    Yea, I was completely bummed out I had to come home last night without any pics or video. Hopefully I can figure out what the heck I did with my digital camera before next weekend. I can't remember if it's somewhere around my house, or I left it somewhere in NC...
    In all actuality, I would say a Mustang II front end would be required to run this engine in a Maverick, not because of shock tower issues, but because of oil pan interference issues. It sure does look cool sitting in there though.
  8. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    back on little cars why not put the sho motor in a yugo
  9. Jamie Miles
    Alto, GA
    I've had a few
    I don't own a Yugo.
  10. Rando76
    Rando76 Member
    Claremore, OK
    haha...Yugo....
  11. Earl Branham
    Lugoff, SC
    Jamie; what are your plans for the electric fan and shroud? If you plan to let it go, let me know. I'm looking for one. That SHO engine should be really unique in a Mav. Keep us posted on the progress!
  12. Rando76
    Rando76 Member
    Claremore, OK
    Jamie, did you ever decide what you are going to put this in?
  13. Jamie Miles
    Alto, GA
    I've had a few
    Nope... I may just sell it.
  14. mbg1973
    mbg1973 Member
    MARIETTA, GA
    1973 MAVERICK 2DR
    sounds cool Hope you figure out what to do with it
  15. starsky74
    starsky74 Technician
    Hackberry Louisiana
    3.0= manual the autos were 3.2 and i have 1
