SCP tubular upper control arms
Discussion in 'Technical' started by jasonwthompson, Sep 4, 2015.
  1. 73curtis
    73curtis Member
    ohio
    Did your ride height change?
  2. 73curtis
    73curtis Member
    ohio
    Did your camber change , what position did you put the ball joint in?
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    You aren't going to see any significant change in ride height by changing upper arms. I recently read that doing the 1 3/4" drop netted 1/4 - 3/8 change in height.
  4. 73curtis
    73curtis Member
    ohio
    Thanks, I like the ride height now and was hoping that changing them wouldn't make a big difference, I was going to use the global west arms , but now I'm leaning towards the Scp ones , I have the global west lowers and adjustable strut rods on now and they work great , but the Scp arms seem like they might have a better bearing in them and the ball joint is adjustable , the global west looks nicer to me but I guess you'll never see them anyway. Also with the scp there are no holes to drill .
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    The front dropped less than half an inch.
  6. jasonwthompson
    Carrollton TX
    I had it aligned right after installation, and I placed the ball joint in the factory position.
  7. 73curtis
    73curtis Member
    ohio
    Thanks
