Seafoam in the intake?
Discussion in 'Technical' started by JoeBob1901, Jun 20, 2005.
  1. stmanser
    Davenport, Iowa
    cool
    this is exactly what i need for my wife's car... it has a major EGR valve problem and i am tired of the truck running like crap... (brand name withheld to protect the innocent)
  2. Mercurycruizers
    Venetia, PA
    I used Seafoam when I first purchased my Comet. The 302 hesitated really bad when I first got it. I swear by Seafoam. I put it in thru the carb, slowly at first, until I had half the can left. Then I poured enough to kill it. Then emptied the rest of the can through the carb. I let it sit for about 10 minutes. When I fired it back up, it smoked liked crazy (white smoke). I kept waiting for sirens. I never thought it was going to quit. Smoked for about 10 minutes. After that, I never had the hesitation. It cleaned out all the carbon. What a difference.....
  3. JoeBob1901
    JoeBob1901 Member
    Hays, KS
    1974 4dr with 302-- 95 Bronco on 1ton axles-40" tires, geared and lockers--86BII 2" lift, 31's
    I've heard people using it for EFI sensors, like putting seafoam in their IAC sensor to loosen up the crud and get the sensor working better. I personally have just cleaned out my IAC with carb cleaner n qtips, but whatever works.
    That's the kind of response i was looking for, i didnt know how you were supposed to use it when pouring it straight down the carb, good to know, i'll go give that a whirl this afternoon, thanks! (y)
  4. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    I am going to go out on a limb here.....Im bad about that anyhow.
    My guess is your talking about a Blazer? Its a very common problem with them.Carbon gets caught in the egr and wont let the door close all the way. best thing to do is to take it off and clean it out.
  5. stmanser
    Davenport, Iowa
    Damn...you are good.... yes..its an s-10 blazer......it has done that on me 2 times..
    i just called checker auto parts....they dont carry seafoam yet.....they said they are working on getting it in.....so i guess i will have to suffer a little longer
    edit: i called autozone down the road from my house....and they have it in stock..YAY!....so on the way home from work today i will stop by... thanks for the info guys...
    its my wife's truck...it is in good shape....interior and exterior...engine runs strong..just has the EGR prob every now and again...and the tranny needs to be rebuilt....i wish it was a c-4.... can get that rebuit cheap....but nope...it is the 4l60e.....will cost 1000-1800 to rebuild
  6. JoeBob1901
    JoeBob1901 Member
    Hays, KS
    Be glad it's not an E40D buddy, its the 1/2ton-1ton updated AOD in 90+ trucks, offered as an "option" until 92, when it became standard, behind diesels, 460s, 302s, 351s, etc. Mine will cost about 2-3k to rebuild :mad:
  7. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    When I went to auto mechanic tech school back in the early 80's our teacher told us that CHOCOLATE MILK poured slowly down the carb. and then flood it out toward the end would dissolve the carbon build up also. Being 19 at the time I went home and tried it on my Comet. Man, :biglaugh: that car blew white smoke for miles. Can't really say I felt any change in throttle response.
  8. bmcdaniel
    When I was much younger we used to remove carbon from the combustion chamber and piston tops by slowly pouring water down the carb of a running engine. Steam cleans them. But you would only do it just before a tune up because it usually ruined the spark plugs.
  9. stmanser
    Davenport, Iowa
    well i put the seafoam in the truck today.....sucked it right in....wow was it huingry.....
    let it sit a good 2 hours....started it up.....and OMG....talk about smokeing.....LOL>...good thing it was dark out....ran it until it got to temp and was pumping the throttle....let it idle..pump the throttle......for about 15 mins...
    shut it down....will run it again tomorrow...
    hope this clears it up..
    thanks
  10. JoeBob1901
    JoeBob1901 Member
    Hays, KS
    Just take her for a run, rather than just sitting in your driveway..gradual accelerations, and WOT situations, it'll clean it out in 5 minutes max
    Stuff is fun isnt it :rofl:
    I did it in the Mav this afternoon for a couple hours, worked well, better throttle response
  11. Hippylong
    Hippylong Hippylong
    72 maverick, 64 dart gt v8 4spd,65 barracuda S v8 4spd
    Seafoam. Today I used the spray can version thru the carb. And 5 oz of 16oz can of liquid thru the oil bottom end..
    Night and day difference.
    Drained oil . The stuff that came out.
    Shoot..
    I might of found a new life form.
    Anyways,I recommend unhook coil and crank a lil at end of draining the flushed oil. Then new filter. Put in 4 qt for 250 6cyl. Crank engine again to prime with new oil for 15 to 30 sec .. then hook up coil and run.
  12. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    good to know. I need to do that for mine. I put in an old truck 302 and its gunked.
    Hippylong likes this.
  13. 71gold
    are you saying ...it runs like a dog?...:huh:
  14. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    Love seeing a thread old enough to have a driver's license come back, haha!
    I am a fan of Seafoam. I usually do a run through the fuel twice a year and then once a year I put the prescribed amount in the crankcase, do a 40 or so mile cruise, and then drain it hot.
  15. Constable
    Constable You have the right to remain silent....or not!
    Portersville, PA
    1975 Maverick 4 door, 1994 Mustang GT convertible
    I did that on advice on a Subaru I used to have. Made a huge difference after it had a chance to work. Pretty much smoked out the neighbors after I first started it up once I let the Seafoam sit in the intake. Looked like a James Bond car.
