Sending Unit Ground
Discussion in 'Technical' started by NewMaverickGuy, Sep 15, 2018.
  1. NewMaverickGuy
    NewMaverickGuy Member
    Birmingham, AL
    1970 Ford Maverick
    What location in the trunk would be a good ground for my fuel cell's sending unit? Also, what connection could i make to make sure my dash is grounded well?
    I want to make sure my gauge reads as accurate as possible.
  2. Craig Selvey
    Pretty much any bare metal location will work. There is a ground screw for the tail-lights located on the center tail-light panel support. Just under the gas tank filler neck.
    NewMaverickGuy likes this.
  3. Krazy Comet
    Assuming a good connection from battery negative to body, any, clean, solid spot on body is as good as next.
  4. Acornridgeman
    Wisconsin
    Just to add …… I don't think you need to do anymore to the dash for a good ground. It is bolted to the body very well through both the brackets and steering column.
  5. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    Thanks guys :thumbs2:
