Serious Problem.
Discussion in 'Technical' started by MavJoe, Jan 2, 2003.
  1. bmcdaniel
    The 170 and the 200 flywheels are the same part number, C6DZ6375A.
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I think AK has cheap 200 I6 flywheels. The 302 flywheels cost alot more than $45.
  3. MavJoe
    MavJoe Certified Lunatic
    Sacramento, CA
    1971 Maverick Grabber
    I e-mailed AK to try and see if they had any complete flywheels for my engine and at what cost. Don't really wanna go through them but I will if I have to. The one I need isn't listed in the catalog and the one they do list says Ring Gear only. so i'm trying their used parts department it doesn't have to be brand new I just want one with a descent ring gear that I don't have to try and change myself with the limited resources I have. I don't have any chisels, the hack saw I do have has dull blades it'd probably take the ring gear off but i'd be out there forever and a day trying to do it I don't have a dramel wheel with a drill or i'd use that so if I was forced to buy just the ring gear i'd end up having a shop put the gear on for me, if I do that I may as well have em resurface the flywheel and the Clutch Preasure Plate while i'm at it, that is of course a last resort option only.
  4. MavJoe
    Sacramento, CA
    Update
    Flywheel is good to go. I had a ring gear put on it and while at it had it resurfaced now it looks like a brand new flywheel. Once I get the Clutch Preasure Plate issue out of the way and a new pilot bearing I should be set to go. Then comes the grueling task of putting it all back together and praying it all works :) I don't wanna have to do this again for a very long time.
