serpentine belt system things.
Discussion in 'General Maverick/Comet' started by Blackdog455, Sep 20, 2009.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I have an AC compressor but no p/s so would I be able to use the p/s pulley for the AC?
  2. Bryant
    mo, i have some crank pullys, an alt pully, and water pump pullies that should work for you. we just need to change the pully/clutch on the ac to a serpentine pully. i think i have an edelbrock water pump too that is reverse rotation. all you should need is the alt bracket. for that you could use a stock one from a mustang, or you can get a march one like used in the pics above.
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    thanks Bryant! I'll work on getting alt bracket . . . I am doing those engine classes starting next week but Tue afternoon I'll swing by if that's ok.
  4. Bryant
    ill be there.
  5. Dave@RACEWARE
    Dave@RACEWARE Member
    New Britain, PA
    73 Maverick Graber 72 Comet GT
    Yes it is absolutely worth some power. Check out this company www.jonesreacingproducts.com . When I was into building cooling systems full time we used a lot of there stuff and that question came up. So one day we replaced one of there employees standard GM truck v-belts systems with one of there multi-belt serp. systems and it raised the idle rpm by 700rpms! The reason is that it take 45% less belt tension to spin the system with out slipage. If you use one of thier radius tooth kits it's even more.
  6. Jamie Miles
    Alto, GA
    I've had a few
  7. Dave@RACEWARE
    New Britain, PA
    Thanks Jamie
