Serpinetine Conversion
Discussion in 'Technical' started by Speedy, Sep 7, 2018.
  1. Speedy
    Speedy Member
    Dallas, TX
    '71 Comet GT
    Anyone do a serpentine conversion? My parts came from a 70's-ish LTD. Wanna setup without AC. I have like a monster looking bracket that holds the alternater and bolts to front of water pump and left head... Any pictures would be so cool...
    Speedy
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I have a setup off a 94 Bronco, it bolts to the heads with two bulky aluminum brackets. If you want something nice looking and compact you will need to look at the aftermarket like March. Probably the best OEM setup would be from a fox body Mustang.
    Here is the Bronco setup.
  3. baddad457
    Try a late 80's full size car. The power steering pump and alternator are mounted together on the driver's side and used a standard rotation water pump. Neat, clean simple setup.
    BBMS18 and Krazy Comet like this.
  4. Krazy Comet
    Except for '86-'91 Crown Vic, Grand Marquis & '86-'90 Town Car, AFAIK all 5.0 serpentine belt setups will require a reverse rotation water pump. The ones I mentioned use a two belt serpentine with a std rotation pump. I can't remember the exact arrangement but I'm 99% belts tighten conventionally and the one belt can be eliminated.
    The setup for Sploder is just plain wierd, entirely different than up to '93 5.0 Mustang and the full size models. The '91-'93 T-Bird & '94-'95 Mustang is possibly similar to splorer
  5. baddad457
    That's the one I mentioned. You can get rid of the A/C which was mounted on the passenger side along with the smog pump. I used this setup for my 89 V8 Ranger swap.
  6. quickshift
    quickshift Member
    Ontario Canada
    71 comet/84 cougar
    comet elect fan install 014.jpg If you don't have PS, keep it simple.This was before the 3G upgrade.
  7. baddad457
    The 94-95 Stang setup used the same timing cover used later on the Explorer/Mountaineer FEAD but the water pumps were different. The mid 88+ up Vic/Marquis/Towncar setup used an aluminum waterpump. This is the pump I used on my Comet.
  8. Speedy
    Speedy Member
    Dallas, TX
    '71 Comet GT
    I appreciate everyones pictures and information. Quickshift, Yours looks great, That's calling my name. I didn't see what it came off of tho...
    Speedy
  9. quickshift
    quickshift Member
    Ontario Canada
    71 comet/84 cougar
    When I built my 84Cougar with an 88 HO engine, I used a March pulley set for that HO. The stock OEM pulleys that I removed are what you see on the Comet.
  10. baddad457
    You can get those pulleys from the Vic/Marquis/Towncar setup too.
  11. groberts101
    groberts101 Member
    Minneapolis, MN
    CFV racing has decent prices if you want a little more bling.
  12. Speedy
    Speedy Member
    Dallas, TX
    '71 Comet GT
    The plan is to use the stock steel pullies blasted and painted. The small mounting brackets are what I'm liking on QuickSilver's car. Mine is like a huge aluminum thing, really ugly...
  13. Krazy Comet
    That small alt mounting bracket is what was used on '70s 302, I have same on my '72 Comet with std belts.
    BBMS18 likes this.
  14. Speedy
    Speedy Member
    Dallas, TX
    '71 Comet GT
  15. Krazy Comet
    Those are for '65/'69(passenger side WP inlet) and are so flimsy I'd never waste my money.
