Setting the valves question
Discussion in 'Technical' started by sazbomb, Sep 7, 2004.
  1. sazbomb
    sazbomb Member
    Tucson AZ.
    1974 Mav 2 dr 250 6 cylinder
    I ran the wet and dry compression and there was improvement the second time around after putting some Marvel oil stuff in and letting it sit for a couple of days. I was able to get the car up to about 25 but it still ran like crap. Mainly acceleration. I would give it gas and it wanted to die out.
  2. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    When was the last time it had a tune up or a carb rebuild it might not all be because of the #5 piston
  3. sazbomb
    sazbomb Member
    Tucson AZ.
    The carb was rebuilt within the last three months. Timing has not been checked due to the fact that I can't find the timing notch.
  4. elliot
    elliot Member
    Boubon MO
    What about plugs, wires, cap , rotor ,and points *if it takes points ?
