shackle ext?????
Discussion in 'Technical' started by 71nogo, May 20, 2010.
  1. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    That means im driving around with my hind end looking like a grocery getter with mag wheels.
  2. PaulS
    Tall shackles cause excessive roll on turns and make the springs sag more quickly in the future. New springs will make it ride better and be a lot safer if you occasionally take turns a bit ....fast?
    Building a set of springs with parts from a wrecking yard is also a good idea - it just depends on how much you want to do yourself. Any kind of spacer will increase the load on the springs when turning and make the car more unstable than it is in stock form. Springs are relatively cheap - new or used - so it doesn't make sense to use anything to "make up" for worn springs.
  3. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    ok, im convinced, do you guy's know that $109.99 price is per side. not including the shackle kit which they recomend? plus shipping.
  4. PaulS
    That makes the $40 wrecking yard price and the extra work almost worth it, doesn't it.
  5. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    as long as it really works:16suspect
  6. maverick75
    It does work, a member here did the research and is running them on his car.
    also the owner of that spring company is a member here: he goes by "kansasJoe"
    http://mmb.maverick.to/showthread.php?t=66507
  7. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    LOL, instead of raising the rear, lower the front ;-)
    Cut front springs, or go find some 6 cyl front springs. But I'm with the rest of guys on this one, replace the rear springs there old and weak.
  8. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    O.K. i think i get the msg. $110.00 plus shipping per side is hard to come up with when your broke.
  9. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    If you use only the bottom or shortest hole, you should be ok with the shackels, but don't expect a lot of lift. The ones on my car were in the top or longest section hole. When I took them loose, the springs snapped back to their normal arch. Using the bottom hole, the spring still has an arch, and the distance between the hanger and spring on the shackle is probably only about 1" different than a stock shackle. I lowered the front by cutting off 1 coil on a stock 250 6 cyl spring, your results may vary.
    Maybe this pics will help
  10. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    mine is a v8 and im sure they need to be replaced. my thought was a shackle ext would give me the lil boost without the expense.
  11. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    where did you get the extencions from/
  12. ford84stepside
    Berry Alabama
    They were on the car when I bought it. As you can see in the pics, I have two holes below the lowest setting. They are of no use and will cause problems if used! I am going to trim mine just below the springs so nothing will be hanging down, just haven't got around to it.
  13. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Sure is a nice looking gold Maverick though. lol
    clint
  14. ford84stepside
    Berry Alabama
    I kinda like it better yellow :D Did you think when it left your house it'd ever look that good?
  15. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    If you want to try shackles, I think I still have the set I took off in my garage. Free of charge if your up in PHX at all.
