Shackle Kit
Discussion in 'Technical' started by Jeff S, Jan 3, 2009.
  1. scooper77515
    Autokrafters sells two sizes, go with the shorter ones. I think they offer 3-1/2" and 4". I got the 4" first and they were too tall. Sent them back and got the 3-1/2" and they were stock sized.
    Also got new 4-leaf springs from JC Whitney, but I hear there is a backorder on them or something, nowadays.
    I also have a little rubbing on my 255/60r15 but I installed Cal-Trac bars to limit up-and-down movement and now it doesn't sink deep enough to hit the tire.
    My a$$ isn't jacked way up, because I tend to like the low and wide stance, tucking the tires as much as possible.
  2. radmav76
    radmav76 Member
    Toledo, Ohio
    1976 maverick soon to be 460 powered...project on hold.
    __________________
    My thoughts excactly....I'll bet it handles great too. (y)
  3. paxtond
    paxtond Member
    Ontario
    1971, 1976 Comets
    Do the shackle kits come with bushings? I actually need front and rear rear spring bushings while I'm at it.
  4. baddad457
    I'm running 295/50's on the back of mine;) No rubbing. Wheels are 15 x 10's with a 5" Backspace. I did roll the fender lips and install the aforementioned helper sprigs though too.
  5. blugene
    blugene Senior member
    Mine didn't. The shackles I bought had the front one already pressed in.
  6. scooper77515
    Bushings sold separately, and are a MUST. Most of ours are pretty messed up after 35 years, if they are even there at all.
    They are cheap.
    And like Blu said, you only need to buy the rear ones at the shackles, the front ones come pressed into the springs.
  7. Jeff S
    Jeff S Member
    NoVA
    none
    Thanks for all the comments guys, with tax time rolling around I might have enough to replace the springs and possibly add another spring to them.
    Alot of you are saying go for it but even more is saying not to...lol I dont know who to listen to. But if I get new springs then I shouldnt need the shackles...I need to find out what Im getting back on taxes.
  8. radmav76
    radmav76 Member
    Toledo, Ohio
    That's not mine, but thanks....I just used scoopers car as an example
  9. blugene
    That blue and yellow racer looks cool. A bit high for me, but maybe that's how it has to be.
    I plan on rolling my lips AND I wear 14s...
    I like this thread, I feel like getting mine back on the ground now. I wanna see what kinda height I have now that I put 4 leaf springs in. :burnout:
  10. PaulS
    most of those "old racers" didn't jack their cars up. They lowered the front and opened the wheel wells up. The car becomes too unstable when it is raised. You do get more weight transfer but the steering goes away under acceleration and the back end gets loose when braking.
  11. Jeff S
    Jeff S Member
    NoVA
    none
    Sounds like a fun way of driving.:rofl:
  12. Mad_Max_Mav
    Mad_Max_Mav Member
    New England
    1970 Maverick, fiberglass nose, blown 351w, 5.13 geared 9" rear, TCI built c4
    indeed :thumbs2:
