"Shelby Drop"
Discussion in 'Technical' started by 71gold, Jan 11, 2007.
  1. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    So for mavericks we would use the early mustang templete?
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    You know we can't remove the turn signal on these cars without a BFH! :D
    It's doing great - it's on an engine stand waiting on me to order the cam and re-stall the converter. I'll have it done in.....say a year and a half.
  3. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    shelby drop
    Been there, done that. Worked great on a 72 Grabber. I did the 66 Stang vision.
  4. bmcdaniel
    I know the early Mustangs needed help in that area for road racing but I've never seen it proven that it's worthwhile on a Maverick or that the same dimensions should be used for a Mav as was used on a Mustang.
  5. 71gold
    ...did you remove the reinforcing plate or did yours not come with one? :huh:
  6. Rick Book
    Rick Book Member
    Thailand
    good call.
  7. jayman
    jayman Member
    San Diego, Ca
    69.5 Maverick/72 Grabber
    The '70 Mavericks that I have looked at did not have the extra reinforcing plate. Neither does either one of my '72 Mavericks. :huh:
  8. jayman
    jayman Member
    San Diego, Ca
    If you measure a '67-'70 Mustang front suspension, the mounting points for the upper and lower controll arms and the springs are in the same place in all three dimensions. Since the parts are all the same dimensions, doesn't it stand to reason that what works for the Mustang should work for the Maverick? (Yes, I know that the Boss 429 is an exception.)
    The '65/'66 Mustang uses entirely different mounting locations, a-arm dimensions, spring mount points, etc. I would doubt that using the '65/'66 mods would be optimum for a Maverick.
  9. bmcdaniel
    What is the difference between the mod for the 65-66 and 67-70 Mustangs?
  10. blue76maverick
    blue76maverick Member
    east tenn. GO VOLS!!
    76 2 door
  11. jayman
    jayman Member
    San Diego, Ca
    http://www.ftw.com.au/content/view/152/50/
    This web site has a good graphic of the measurements for the 65-66 and the 67-70. After looking at this, I went out to the garage and checked the template that I had used. Whew! I used the correct 76-70 template. :bananaman
    Sometimes, my memory, she ain't so good....
  12. David74maverick
    Arizona
    what would be the recomended springs for this drop? on a maverick obviosly.
  13. PaulS
    Stock springs - it may lower the front a little but not much - especially if you use the wedge block to correct ball joint angles.
  14. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I am still trying to figure out why folks say that this mod lowers the car?
    If you lower the suspension mounting point on the body, then the body should be raised...
    Conversely, when you raise the suspension, drop spindles for example raise the spindle, lower the car.
    I am really asking!
    I have heard everyone say the car lowers, but I can't understand how.
    Any explainations?
    Thanks
    Dave
    Btw:
    A little O/T, but I been dying to know...
    Where can one get shorter front springs for a Maverick?
    I know I can cut, but new springs would be nice, and so would a 'clean' spring rate.
  15. ratio411
    ratio411 Member
    Pensacola
    Okay!
    That link was great!
    It answered my question on how the mod lowers the car.
    Thanks!
