Shelby Maverick Build on Discovery Channel
Discussion in 'Mavericks/Comets in the Movies and Other Media' started by garrettmuir1227, Jun 30, 2014.
  1. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Those were LEDs on that car, or at least the light bulbs were.
  2. rayzorsharp
  3. mavgrab302
    And with their LED set all you have to do is drill four holes to mimic the 66 mustang tail light housing. The rest of the light will rest on top of the tail panel with 3m sticky tape... So if you ever want to go back to stock you just weld up the 8 holes...
  4. rayzorsharp
    Unless you do it the hard way and replace the entire panel with the Shelby one. Lot more work but I like it. Just needs to be done by an experienced body man. And if you go that route, use the steel panel rather than the Fiberglas one. I've used both. If I had used steel the first time I wouldn't have had to redo it later on. :)
  5. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    I agree with Ray. The way they did it on the show was a cheesy way of doing it and you can tell because the lights hung below the raised portion of the stock tail panel.
    If you look at pictures of Ray's car you will see that the tail lights look and fit like they were factory and not some bolt on after thought.
    Ray's car is the closest I have saw to a really Maverick Shelby if they ever made one. I forgot they made 300 for the Mexican market.:rofl:
  6. mushoss93
    mushoss93 Member
    hazlehurst, ga
    '75 comet
    Tail lights
    Thanks Rayzorsharp.
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Didn't the original Shelby Mustangs all have the fiberglass panel?
    I'm not an expert on Shelbys.
    I like the way my friend did his. He wasn't trying to make the car look like a Mustang, but rather a Maverick with really cool tail lights.
  8. Dave B
    Yes, and it's pretty cheesy, they hacked out the original tail light opening, and drilled a couple other holes, it you've ever see a stripped down Shelby, you'd wonder what they were thinking. I'll see if I have any pictures.
  9. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    How Quick a 1970's car went had a lot to do with how the car was equipped ! A lot of the cars that were tested that recorded poor times were high gear Auto cars, some even had open rear diff! I remember Car Craft testing a 427 cougar
    the car had 3.50 gears and an open diff! Whay even post the times for such a car! One of the guys I used to race with had a 1970 454 LS6 Chevalle all stock with only headers and slicks the car run 12.01 at 112!
  10. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Wow, just like those Mavericks with "stock" 302s that ran low 12s with 4.11 gears & slicks (LOL).
  11. Krazy Comet
    I can believe a 1970 LS6 Chevelle with OPEN headers, proper tune and slicks could run 12.0... Of course it'd need some gear but many of those cars had posi 3.73 to 4.11 from factory...
    BTW the '70 LS6 was rated 450Hp, with mods mentioned they came real close to producing the numbers...
