Shift kit to C4
Discussion in 'Transmissions' started by FinnMav, Mar 16, 2019.
  1. FinnMav
    FinnMav Member
    Finland
    ´74 Maverick 2dr
    Hello there!
    I just bought a master kit to my C4. While it is opened up and repaired, it would be easy to add shift kit in it.
    Are they worth of money? Does it make a difference? Motor will have approx. 300 hp and i think i will put in a about 2500 stall converter.
    Car is '74 maverick.
    Thanks!
  2. 71gold
    I think worth the money.
  3. Krazy Comet
    For 300Hp, a C4 should absolutely have a shift kit installed. In stock form, they are barely adequate for 200Hp.
  4. FinnMav
    FinnMav Member
    Finland
    ´74 Maverick 2dr
    Thanks for the info. Im going to install that shift kit. Is some brand specially good or are they all ok?
  5. Krazy Comet
    Some are better than others, I've had good results with Trans-Go. Those have three options for amount of shift firmness, you probably don't want to use the race version.
  6. FinnMav
    FinnMav Member
    Finland
    ´74 Maverick 2dr
  7. Krazy Comet
    Yep, that's the kit.
  8. FinnMav
    FinnMav Member
    Finland
    ´74 Maverick 2dr
    Thanks!! :bowdown:
  9. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    You may also want to look at your intermediate servo and piston. Performance Automatic makes a nice upgrade.
  10. FinnMav
    FinnMav Member
    Finland
    ´74 Maverick 2dr
    Can you put a link or something? Im operating from Finland :happy:
  11. greasemonkey
    Sedalia,MO
  12. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    It's amazing what a difference a servo can make. I installed one in my GMC 700R4 and it was a huge change.
  13. FinnMav
    FinnMav Member
    Finland
    ´74 Maverick 2dr
    Thanks for the link, greasemonkey.
    What kind of change are we talking about? Remember, Im new with these things :p
  14. greasemonkey
    Sedalia,MO
    Basically it's all about how much pressure they apply to the band. The factory used several different ones obviously some better than others. But, the pa best them all.
  15. RMiller
    Kennewick, WA
    Better holding power under load and firmer shifts. Mine was in a pickup I towed a horse trailer with and those early 700R4s needed all the help they could get for longevity!
