Shifter hole pic needed!
Discussion in 'General Maverick/Comet' started by BroknNx, Nov 17, 2020.
  1. BroknNx
    BroknNx Member
    Santa Maria, CA
    73 Maverick
    Does anybody have a picture of their manual trans floorpan with the shifter hole showing? I pulled my carpet today, and discovered the sound deadener pad under the carpet had a good punch out template of where the hole should be. The problem is, the deadener pad looked like it was shifted slightly toward the drivers side. Great if it’s supposed to be offset, but I don’t want to cut until I know the hole is somewhat close to where the factory intended it to be.
    Thanks!
  2. 71gold
    hole for what trans. shifter?
    3, 4 or 5 speed
  3. Powerband
    Powerband Member
    NY's \H/
    tranny ?
    5 speeds are larger and may need tunnel mods
    T5
    [​IMG].
  4. dyent
    dyent Member
    vancouver bc
    This picture may help...........
    David
  5. BroknNx
    BroknNx Member
    Santa Maria, CA
    73 Maverick
    The factory hole for the shifter to stick through the floor using a 3 or 4 speed manual.
  6. BroknNx
    BroknNx Member
    Santa Maria, CA
    73 Maverick
    You can see the scribed mark in yellow paint pen where the sound deadener was. It’s offset slightly to the drivers side. Is this correct or should the hole be dead center in the tunnel?
  7. BroknNx
    BroknNx Member
    Santa Maria, CA
    73 Maverick
    Another...
  8. dyent
    dyent Member
    vancouver bc
    Center the shifter hole cutout between the 2 "Dimples" on your tunnel for factory location.........
    David
  9. BroknNx
    BroknNx Member
    Santa Maria, CA
    73 Maverick
    Saw your pic above, exactly what I was looking for. It looks like your image has a ‘hump’ added to clear the shifter mechanism. Is this how it was done at the factory, or did you add that part?
  10. dyent
    dyent Member
    vancouver bc
    That is a factory installed "shifter hump", it has 4 threaded holes to attach chrome bezel which secures the rubber boot. If you are installing an aftermarket shifter, you do not need the hump, I have installed a Hurst shifter with Toploader 4 speed in my 74 Comet, which like your 73 Mav, had a column shift auto.......
    David
  11. BroknNx
    BroknNx Member
    Santa Maria, CA
    73 Maverick
    Perfect! Exactly what I was looking for. Thanks to all!
  12. mojo
    How thing's going David? Hope all is well! You ever considered going to a 5 speed w/ that 3.70 gear combo? Would be a nice combo if you do much highway speed driving.
  13. Mavman72
    Just so your aware...That shifter hump is used for automatic floor shifter applications...Not necessary for standard shift apps...
    Craig Selvey and mvw66gt like this.
  14. Craig Selvey
    Here are another pictures as well. And as stated....the "hump" was only on automatic floor shift cars.
  15. BroknNx
    BroknNx Member
    Santa Maria, CA
    73 Maverick
    Thanks for the pics. I’m a huge proponent of ‘measure more than twice’ before cutting anything. Seeing the factory hole as many times as possible will prevent any butchery!
    mojo likes this.
