shifter linkage
Discussion in 'Technical' started by 71mavkidd, Jul 25, 2008.
  1. maverick1970
    maverick1970 MCG State Rep
    Missouri
    A little sooner and he could have just drove to Joplin from Oklahoma to get it.
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    There is a tube that runs down thru the column that controls the shift arms outside. First, check to make sure it's not in two gears-pull up on one of the shift arm and push down on the other....that should unlock it if it's in two gears. Then put both arms in neutral, you will be able to tell as the motor will no longer try to turn when you rock the car. Then try the shifter again. If it still doesn't move the arms out side, it is probably broken something in the column, or the tube itself is just worn out. It might be hard to find parts to rebuild the column. Your only choices then will be to either replace it with a known good column, or do the floor shift conversion....
  3. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    in that case i am ultimately going to put it in the floor but until then i need a good collumn if i can find one close.
  4. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    :yahoo: about what would that cost and how do you want the money?
  5. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    the broken part is inside of this?:huh:
  6. PaulS
    If the levers at the bottom of the column aren't moving with the shift lever then it is likely that there is something broken or worn out inside.
  7. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    I got a good collumn today :dance:(thank you jack) but i think it is stuck in 2 or 3.. anyway the small arm(gears 2/3 i think) that connects to the tranny will not move it is stuck
  8. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    the collumn is stuck not the trans... i have not bolted it in yet? Any ideas as to what that is?
  9. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    nope my only car friend is in new mexico right now... and jammed is definitely what i am thinking just cant get it unjammed :hmmm: i am so close to taking a spin around the block:badwords:
  10. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    i also notice that the r/1 arm moves with no resistance and has no effect on the other end
    does anyone possible have a blown up pic of this?
  11. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    thank you. :urock:and i figured it out. DOH :slap:the key was off :hide:
    but now it wont start and i know that you mentioned adjusting the ignition.... what does that mean exactly, and how do i do it?:huh:
  12. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    :bump:i really need some help
  13. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    yes sir.. thank you again.. it works great... its not in awesome driving condition only one seat bolted in and several other things like that:dance: but it does drive now and i drove it around the mile section that i live on a couple of times and do occasionally take it places even though i have yet to get a tag for it :drive:
