Shock Thru Trunk!
Discussion in 'Technical' started by Slider28, Mar 2, 2010.
  1. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    Many a year ago my dad sent both the rear air shock on his 69" Torino through the floor,he just welded the metal back in and then added a 1/4" steel plate on both sides,never happened again even when he had the car run in the low 11's with a big block and 4-spd
  2. Earl Branham
    Lugoff, SC
    No, they are not adjustable, but will give you a good ride, and much better handling. The air shocks have no cushion, and will bounce you around, as well as tear up your car. Get 4 leaf rear springs, and that should put you up a bit. I had them on my car, and they were a bit tall for my taste, but if you want it up, that is the best way to do it.:)
  3. Slider28
    Slider28 Member
    San Antonio, Texas
    72 Maverick Grabber 302
    anyone have any pics of the 4 leaf rear springs on a car to see how the lift is???
    CHaz.
  4. Slider28
    Slider28 Member
    San Antonio, Texas
  5. tody
    tody Member
    cologne, germany
    there was a group buy on these springs a while back - there must be some pictures around...
  6. skin
    skin Registered User
    Northeast Ohio
    '73 357ci Grabber
    Brings to mind the day my shocks broke through as well. Was running air shocks with too much air and the shocks just beat the crap out of the metal back there. Took it to the local Ford dealer (this was in the early 70's) and they took an exact copy of the inside of the trunk where the shocks mounted (entire area directly under where the rear speakers are mounted) and cut out a piece of 1/4 " steel and welded it in. When they were done it looked factory and never broke again as long as I owned it!
  7. Craig Selvey
    Here is 4-leaf:
  8. apotter80
    apotter80 Member
    charlotte, MI
    1971 maverick grabber(CLONE)
    if you want to hike up the ass end a little bit, why not just get adjustable rear shackles? :hmmm: had some on mine when i bought it. just be aware that you will lose a little on the handling side if you jack them up too far.
  9. indyman13
    indyman13 Member
    Little Rock, Arkansas
    Maybe I was lucky the 3 years I had my Maverick in the 70's. Monroe air shocks at about 60psi and towed a ski boat for two solid summers. Never a problem. How much do y'all think metal fatigue might be playing a role today? I'm running the same setup on mine now as back then so it's probably a good idea do so some of that plate or tab fabricating stuff being talked about. I've got the steel and welding covered and I'd guess it'll save a Benjamin (or two) over the 4th leaf route. What did the spring work run you guys? (just adding---not a total re-do)
  10. Slider28
    Slider28 Member
    San Antonio, Texas
  11. Earl Branham
    Lugoff, SC
  12. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    height
    You could also try some different shackels....until you make a spring change.
  13. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Just put bigger tires on the back. That's the easiest and cheapest thing to do.
