Should I buy this maverick
Discussion in 'General Maverick/Comet' started by Rhab1990, Dec 28, 2016.
  1. Rhab1990
    Rhab1990 Member
    Baltimore
    Maverick
    My neighbor is selling his maverick, basically a roller, with 302 engine, car has no bumper, grille, headlights or trim, rear bumper, interior at all, tail lights, markers, or transmission and driveshaft, it was a 6 cylinder originally but it has 5 lug wheels so someone must have changed it for an 8 at some point, he wants 750, does this seem reasonable or should I keep looking? Also the body is in good shape, little rust, some poor bondo work in quarters and rockers
  2. rthomas771
    All 73-up Mavericks came with 5-lug wheels. Sounds over priced with all that's missing
    Crazy Larry likes this.
  3. Rhab1990
    Rhab1990 Member
    Baltimore
    Maverick
    It's a 71
  4. William623
    Orlando
    1973 ford maverick grabber
    Post some pictures of it. If the body is in nice shape it is worth it. If not, then sounds like a parts car.
  5. Rhab1990
    Rhab1990 Member
    Baltimore
    Maverick
  6. Hotrock
    Munroe Falls, Ohio
    Welcome to the site from northeast Ohio!!! :tiphat:
    Keep looking; you would spend more on missing, worn out and bent parts than that particular car would be worth.
  7. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    Body is beat up, and someone has done body work on it, I'd run away, especially with all that's missing.
  8. Rhab1990
    Rhab1990 Member
    Baltimore
    Maverick
    Thanks for the advice! Is there a price where you'd actually consider working with it? Or part it out and let it go
  9. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    Personally, having done a lot of body work, and seeing prices, I'd pay just a little bit more and get a straight roller, if you're looking for a roller. It's always worth it in the end to get something with a nice, straight, mostly rust free body, because you'll end up paying way more than that extra for the body work, either by paying someone to do it, or with loads of your time.
    If there are some good parts worth selling, you could try to offer him... $400, and then sell, or use the parts. If it has granada discs, those can be parted, IDK if you'd be able to sell any body parts off of it, I see rot coming through and lots of sketchy filler work. Maybe the drivers side is better?
    Just my 2 cents
  10. William623
    Orlando
    A lot of work in that car...
  11. x72COMETx
    x72COMETx Member
    Vallejo CA
    If the tires were new they would be worth more then the car
  12. Acornridgeman
    Wisconsin
    You say it has a 302 included? If that engine is fresh, there is $750 right there.
    Need more info about the motor before I decide .......... :cheers:
    mojo likes this.
  13. 71gold
    :Welcome:...:Handshake:
    appears to be a non A/C car.
    I would walk, fast...:outtahere:
  14. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I'd offer $400 and they can take it or leave it.
  15. 71Mavrk
    71Mavrk Member
    Nevada
    He looks desperate to me. Offer him $200 and use it as parts to rebuild a better Maverick when you find one. You will miss the 5 lug parts when you locate a 4 lug that you want to put a V8 in.
    http://york.craigslist.org/cto/5935219096.html
    Micah
